First post, by JustJulião
- Member
I know how to replace caps but I have no knowledge about it.
I must have a bad cap on my Epox EP-51 MVP3E-M because I need to power it on twice when @100MHz FSB.
It powers on OK at 66MHz.
Problem is, it has been recaped and they all look good. Should I replace "minor" caps that are likely older ? Should I replace "major" ones with better quality ones even if they look good ?
What about this little yellow ones near the ATX connector ?
