Retro Rig Photo Thread
Reply 2320 of 3051, by PD2JK
Ok, my turn.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2321 of 3051, by chrismeyer6
Those are awesome looking cases. I'm curious as to what the ecokeys do?
Reply 2322 of 3051, by Obijuan1983
My recentrly restored-Retrobrighted PC's 😀
Reply 2323 of 3051, by Cosmic
Obijuan1983 wrote on 2022-09-07, 19:24:
My recentrly restored-Retrobrighted PC's :)
These are terrific! They are all AT cases? They look almost brand new. :D
UMC UM8498: DX2-66 SX955 WB | 32MB FPM | GD5426 VLB | Win3.1/95
MVP3: 600MHz K6-III+ | 256MB SDRAM | MX440 AGP | 98SE/NT4
440BX: 1300MHz P!!!-S SL5XL | 384MB ECC Reg | Quadro FX500 AGP | XP SP3
Reply 2325 of 3051, by chrismeyer6
DerBaum wrote on 2022-09-07, 20:05:
chrismeyer6 wrote on 2022-09-07, 14:58:
It makes the PC go sleep. Like closing the panel on a laptop. A hardware hibernation button...
Here is a germen commercial featuring the ecokey https://www.youtube.com/watch?v=Su7YV01Ebi4
That's a neat feature. Thanks
Reply 2326 of 3051, by devius
PD2JK wrote on 2022-09-07, 13:15:
Ok, my turn.
Do you have both connected via KVM, or is it just for the picture? 😁
Reply 2329 of 3051, by Obijuan1983
Cosmic wrote on 2022-09-07, 20:02:
These are terrific! They are all AT cases? They look almost brand new. 😁
The 3 at left are AT cases, the far right is a ATX with PII system inside.
Some photos from Retrobright, panels at first photo treated without taking photos before.You can see at the plastic base of one tower the difference and at drives...
Reply 2331 of 3051, by bjwil1991
"Okay, my torn." - Gru
The attachment IMG_20220902_002455583_2.jpeg is no longer available
Austin M1RC Pentium 100 2.9V 16MB RAM CL-GD7543 ES1688F 800X600 TFT 2GB SD (SD2IDE used since I don't have real drives) 1.44MB FDD
Reply 2332 of 3051, by PD2JK
chrismeyer6 wrote on 2022-09-07, 20:09:
Yep, as long as the mainboard has a SMI header to connect the button.
devius wrote on 2022-09-07, 20:35:
Ok, my turn.
Invisible KVM switch. 😁
Reply 2333 of 3051, by MMaximus
My recentrly restored-Retrobrighted PC's :) […]
Nice fleet
is this an Alfa GTV outside ? 😀
Hard Disk Sounds
Reply 2335 of 3051, by Obijuan1983
MMaximus wrote on 2022-09-08, 09:39:
Nice fleet
Thanks mate, try to make bigger team!
The car is an Alfa 156 by the way!
Reply 2336 of 3051, by PD2JK
PARKE wrote on 2022-09-08, 11:07:
PD2JK wrote on 2022-09-08, 04:27:
Do you still have the motherboard that came with the case ?
Story time, which is about the AT system. It was our first new computer at home. A few years later we sold it to someone who was handy with computers, which became a very good acquaintance after that.
10 years after that we were cleaning his shed and the system came to light again and I could have it. The FIC VA-501 was replaced by a PCPartner board. I know it came with the VA-501 because there was a sticker at the bottom.
There are not much mainboards with a SMI header for this 'Green Switch'...
TL;DR: Yes, after some swapping. 😁
Reply 2337 of 3051, by Obijuan1983
Intel DX4 100MHz Build
finished!
Reply 2338 of 3051, by Obijuan1983
Update adding an Iomega Zip Drive 250MB and a Diamond Stealth 3D 2000 Pro
Reply 2339 of 3051, by Private_Ops
Just one kinda crappy pic. Will have to do a proper photo shoot.
Specs:
Celeron 366Mhz
64MB PC66 SDRAM
Intel AL440LX (onboard Yamaha sound chip)
Samsung 4.3GB HDD
44x CDROM
Intel 10/100 PCI NIC
3DFX Voodoo 3000D
