First post, by Juason
Well, I had Tegel's Mercenaries running, and thinking that Strike Squad would use a similar DOS interface - I figured it would be easy to get working as well. Unfortunately that is not the case.
Again my system is a 2100+ Athlon XP, WinXP Pro w/ SP1, 1GB ram, using VDM Sound 2.0.4 w/ Update 1. I can attempt to play SS with, or without sound, through WinXP's emulation, or with VDMSound, or with DosBox, and with no luck. EVERY time I get the same error when launching it. This is:
Interrupt 0DH, GENERAL PROTECTION FAULT possible illegal segement error code = 8050
eax = 00F00177 esi = 000C0000 flags = 3206 ds = 01BF
ebx = 034ED90C edi= 000C000E eip = 00004229 es = 01BF
ecx = 034ED90C ebp =00C09FFF cs = 0197 fs = 0187
edx = 000C0E00 esp =000C0DF8 ss = 01AF gs = 017FSound Driver isn't in memory
Again, I've tried a lot to get past this, even no sound/music - and to no luck. Any help would be appreciated as usual 😀
http://www.ughq.com-SE Michigan's LAN gaming Headquarters!!
***poof!***
Ninja Vanish!
Reply 1 of 9, by Snover
Is this an error the game is giving you or an error Windows is giving you?
Yes, it’s my fault.
Reply 2 of 9, by Juason
This is the error that appears on the command line. The game doesn't even really launch, just spits this back out in the dos prompt. I saw another recent post about underneath a steel sky I think, and his error looked identical....
Reply 3 of 9, by Nicht Sehr Gut
You have a knack for picking the hard ones.
I can't get Tegel's Mercenaries running without switching off digital audio. I'm getting the same message as you for the fail (GPF), but I'm suspecting it may actually be a corrupted archive.
DosBox is no good for either of these (actually, it will run Mercenaries, but without Digital audio, so there's precious little reason to...).
Reply 4 of 9, by Juason
Yeah this is bugging me. It looks like a WinXP thing. Strike Squad works fine under Win98 on my other PCs, but alas, I get the same error on my other WinXP boxes.
Reply 5 of 9, by Juason
With Mercenaries it looks like the digital sound problem is caused by the game's inability to see what DMA the soundcard is on. I always get a "sound DMA not found error" I can't change the dma value from 1 either to check. Adlib sound doesn't come through either, but it runs. Music is good all around. With speedset the game is playable, but yeah..sound effects would be nice 🙁
***poof!***
Ninja Vanish!
Reply 6 of 9, by thor44
I have been trying to get my old favorite Strike Squad working on my XP PC as well. I get a very similar error message when the game refuse to start. I am very new at trying to make old games run under XP. My first PC used DOS so I am faily familiar with it but is has been a long time since I messed with it. I would be most grateful for any and all help anyone can give me.
Reply 7 of 9, by Juason
Well its nice to know I'm not the only fan of strike squad left 😀 Unfortunately I don't forsee us being able to play it under WinXP anytime soon. The problem is apparent in all situations, and short of one of the senior members creating a patch for the game we're out of luck. Not a single emu out there changes the error, and its not even sound related. Luckily I can still fiddle with Tegel's Mercs (albeit without digital sound) for now...gotta love that theme song!!!
***poof!***
Ninja Vanish!
Reply 8 of 9, by thor44
So you are able to get TM to work by going without sound? I will have to try that, it is not as good as Strike Squad but it will do in a pinch.
Reply 9 of 9, by Juason
Yes, it works nicely with only music. BTW, it plays somewhat fast, but I found that by holding down the right mouse button it works in normal speed 😉 Or..use speedset / pitset and just manually slow it down. I forgot how hard the controls can be heh. What's interesting though is it didn't crash during the hour I played....something it used to do VERY frequently on my old 486... odd how that stability thing goes.
***poof!***
Ninja Vanish!
