Need for speed 2 SE shaky cockpit
Reply 20 of 33, by BEEN_Nath_58
ReignerDeustcher wrote on 2022-09-30, 19:44:
BEEN_Nath_58 wrote on 2022-09-30, 05:48:
ReignerDeustcher wrote on 2022-09-29, 19:16:
what??? i didn't posted any link here!
Maybe because of the source we discussed. Anyways, let me put the main thing here:
Regardless of release, testing the same level, I have the same result in Pentium 2 Windows 98, Pentium G2020 Windows XP and Windows 7, Ryzen 5 1600 Windows 10 and Windows 11.
go get that version that i told
Yes as I said, I used the version as you specified, which is nothing more than a few patches applied. On the same map, the cockpit shake happens and on every CPU I tested.
Reply 21 of 33, by ReignerDeustcher
BEEN_Nath_58 wrote on 2022-10-01, 06:30:
seriously? but i'm not getting the problem with this version.... 0_o
Reply 22 of 33, by BEEN_Nath_58
ReignerDeustcher wrote on 2022-10-02, 16:48:
Just to be sure I am not seeing the wrong thing the cockpit shake you refer to is "the high frequency shake in cockpit view when you drive very fast"
Reply 23 of 33, by ReignerDeustcher
BEEN_Nath_58 wrote on 2022-10-02, 18:05:
no, it happens when you turn the corners, the image starts to jump like when you go fast and get offroad in grass, etc
Reply 24 of 33, by BEEN_Nath_58
ReignerDeustcher wrote on 2022-10-02, 23:59:
You are correct. I was just looking at fast speed, and didn't notice that shake while turning. Let me try turning in Windows 98. Who knows, it might just have been an original game bug that nobody noticed, let ne see...
Reply 25 of 33, by BEEN_Nath_58
Can you check if the problem exists in this video, and the time stamps where they happen (just for verification):
https://youtu.be/ajdJOMdzRaY
Reply 26 of 33, by BEEN_Nath_58
Nevermind, try extracting and putting this config.dat in "...\FEDATA\PC\CONFIG"
Reply 27 of 33, by ReignerDeustcher
BEEN_Nath_58 wrote on 2022-10-04, 07:24:
in 0:55 happens
my next goal now is how to improve that software image, i don't want to buy a smaller monitor
Reply 28 of 33, by BEEN_Nath_58
ReignerDeustcher wrote on 2022-10-04, 20:52:
in 0:55 happens
So that config.dat fixed it?
Reply 29 of 33, by ReignerDeustcher
BEEN_Nath_58 wrote on 2022-10-05, 09:33:
in 0:55 happens
no, the version of the game that i told fixed it
Reply 30 of 33, by BEEN_Nath_58
ReignerDeustcher wrote on 2022-10-05, 21:45:
in 0:55 happens
Wait I don't understand. You couldn't figure out why your game was shaking in cockpit view, then you found out a different version exists where it doesn't shake but you didn't know why. But you also couldn't find what was different, so I found it for you, its the config.dat, modified by Verok.
Regarding the resolution, you can try using some bilinear filters of DxWnd + upscaled resolution.
Reply 31 of 33, by Azarien
BEEN_Nath_58 wrote on 2022-10-04, 07:04:
The excessive shaking also happens to the car itself when in outside view. So it's the car that is shaking, it's just more noticeable when we are in it.
Reply 32 of 33, by BEEN_Nath_58
Azarien wrote on 2022-10-08, 08:36:
Hmm that's what I meant. People maybe didn't like it so it was fixed "by a mod"
Reply 33 of 33, by ReignerDeustcher
BEEN_Nath_58 wrote on 2022-10-06, 15:41:
mmm but i don't remember having the game with this kind of problem back in 1997, the gameplay was so smooth... but thanks anyway
