Reply 22860 of 29970, by Shponglefan
- l33t
BitWrangler wrote on 2022-10-09, 04:45:Due to minor differences in geometry translation and there not really being an official standard until midway through the 1990s, minor differences meant that not every HDD formatted on given controller, with given BIOS and chipset, could necessarily be read on a different machine with a different controller/BIOS/chipset. The problem seemed to go away totally after ~27GB limit was sorted out, existed in edge cases in the post 8GB days, and everything before that, 90% of the time it worked all the time, though things get worse the further back you go. Maximum reliability on anything older than about 1998ish is best achieved by formatting your IDE drives on the machine you're gonna use them on... even though XT-IDE code and hardware is later you've still got original BIOS and chipset quirks that might pee in your cheerios. Some of it might be due to lack of care in making certain timing operations independent of processor execution speed.
Very good points. After setting up a brand new card everything does seem to be working fine now, so I am definitely going to keep all this in mind for future setups.
