Reply 440 of 1356, by Sphere478
Very nice 😀
Obviously you can’t test this one, but on the next one if you give me the go ahead to remove those capacitors at the edge I can make it even smaller.
How does the fet alignment look?
Sphere's PCB projects.
Reply 441 of 1356, by feipoa
I personally think the caps on the front tab look neat, but if they are removed, the most you could shave off is 1.5 mm because the trimmer is already touching the heatsink.
The alignment of the VRM is perfect. I'm also glad we rotated the socket to have the direction of the words in the same direction.
The attachment IMG_0386.JPG is no longer available
The attachment IMG_0387.JPG is no longer available
Reply 442 of 1356, by maxtherabbit
feipoa wrote on 2022-10-29, 12:06:
The soldering order is as follows: […]
Orient the PCB so that the bottom surface is facing up. Insert only the outer-most perimeter of the male-to-male PGA-132 pin headers. Due to the wider than expected butt-ends of these pins, you may want to hover them over the PCB by about 0.25 mm using an appropriately sized piece of paper. A photograph is a good example of this thickness.SXL2_interposer_soldering_order_1.JPG
While holding outer-most perimeter pins in place, turn the PCB over and solder the through-hole pins to the PCB.
Once all of the outer-most perimeter pins have been soldered, remove the paper offset and install the PGA168 socket. The less plastic on the socket the better.
While holding the PGA168 socket in place, turn the PCB over again and solder the through-hole pins of the PGA168 socket to the PCB.
Insert the remainder of the male-to-male machine pin headers, again using something to offset the pins by ~0.25 mm. Since you will need to remove this piece of paper, you will need to solder the middle perimeter, remove the paper, then solder the inner most perimeter pins.
nice, does the usage of individual header rows affect alignment into the 386 socket?
Reply 445 of 1356, by feipoa
Alignment of the male-male machine pins hasn't been a problem for me with the last two prototypes I assembled. For a good fit, be sure to gently sand down the ABS plastic from cut end of the header.
Reply 446 of 1356, by RayeR
I don't understand a bit why all this waste of time with wrongly manufactured PCB and why it even happened. Once I made a mistake when ordered a soldering stencil in JLC - I uploaded corectly SMtop and SMBottom gerbers but clicked only TOP to manufacture instead TOP and BOTTOM on one sheet by mistake. After a short chat with JLC I had to admit it was my mistake and ordered the BOTTOM side stencil in next batch but I wouldn't expect they will change my order. The same I wouldn't expect when I order 4-layer PCB with 6-layer data they will manufacture 6-layer for price of 4-layer, they are not idiots. Also there's an option during gerber upload to pair layer numbers with gerber names. Sometimes I intentionally used to manufacture less layers than the project already had when I made a cheap dummy PCB just for mechanical purposes to complete a mechanical prototype to be sure just before mass production...
If this was just a soldering lesson and checking that some parts doesn't mechanically collide then OK but it would be 2 layers enough...
Reply 447 of 1356, by feipoa
We do not have a deadline. It's all good. Their script should be detecting the proper number of layers, but it isn't and we'd like to find out what is causing this.
Reply 448 of 1356, by Sphere478
We were checking for a loophole 🤣
He is just making sure it assembles good so if there is a problem we can fix it before ordering the next one (and selecting 6 layer this time haha) but if that trick had worked we would have all been happy to get cheaper pcbs. So rather than criticizing maybe thank us for taking the time to check and be sure we couldn’t save you money.
Reply 449 of 1356, by feipoa
If anyone is in a hurry for whatever reason, you are more than welcome to order your own PCBs for testing.
Reply 450 of 1356, by debs3759
Personally, as I can't afford to get involved in testing, I'd rather have something that is well thought out, tested and working next year than something that is cheap and imperfect yesterday. I appreciate the time and money a few of you are putting into this project.
Reply 451 of 1356, by Sphere478
debs3759 wrote on 2022-10-30, 19:19:
I think it has turned out very good so far. Yes still prototyping 😀 but “feels” like we are close.
Very curious for the actual test run on a motherboard :p fingers crossed.
That resistor being so close to the capacitor (latest version, not on physical prototype feiopa has) while totally fine is bugging me.
I can move it to the back? Thoughts?
Reply 452 of 1356, by ChrisK
feipoa wrote on 2022-10-28, 13:48:
Of more concern for me right now is the distance from some of the PGA-132 holes to the smaller vias. Sphere, what is the smallest gap here?
I was looking at my male-to-male machine pins and it looks like the head of these have a wider diameter than that of standard PGA socket pins. Standard PGA sockets have a 1.32 mm diameter, while my gold male-to-male pins has 1.79 mm. I hadn't noticed this.
Maybe you can fill the area under the male-to-male pins with silk screen to cover the vias. This should be resistant to soldering heat and give enough isolation without taking too much height.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 453 of 1356, by feipoa
Where do I buy a paint brush can of silkscreen? And how thick does it go on?
Is there anyone else familiar with KiCAD? The JLCPCB guys said there's only 4 layers in the gerber folder (photo attached). So it sounds like two of them (the gerbers) didn't get generated? Anyone know how to generate them? I am unable to open Sphere's KiCAD project on my system (Ubuntu 18.04 + KiCAD 4.07).
Also, it sounds like Sphere will be away from a computer.
Reply 454 of 1356, by maxtherabbit
Just tried to see if I could plot them for you but I can't open the pcb file either. His version is too new
Reply 455 of 1356, by Sphere478
I can look at it when I get home. Tonight or tomorrow evening.
Sounds like I may have the plotter set up wrong.
I can add silkscreen over the vias no biggie
Reply 456 of 1356, by ChrisK
feipoa wrote on 2022-11-01, 12:35:
That must be done by Jlcpcb of course.
Just add a simple rectangle over all the pins in the silk screen layer in kicad. Jlcpcb will automatically set the through holes free. The vias will be covered.
Reply 457 of 1356, by MJay99
If it's just because you're only seeing KiCAD 4 in Ubuntu 18.04, there's this PPA for KiCAD 6:
https://launchpad.net/~kicad/+archive/ubuntu/ … ad-6.0-releases
Seth Hillbrand works on KiCAD, so it shouldn't be a risk.
Edit: I've just downloaded the latest .zip - the included gerber.zip doesn't include the In_1.Cu and In_2.Cu. Opening the project in Kicad 6.0 and starting the gerber export, I'm seeing those two layers aren't checked for export:
The attachment gerber-export.jpg is no longer available
Reply 458 of 1356, by Sphere478
ChrisK wrote on 2022-11-01, 18:25:
So silkscreen cut by solder mask DRCs can be ignored? It won’t paint over the pads?
Reply 459 of 1356, by Sphere478
Okay, I'm back in front of computer! 😀
The attachment CPUInterposer386-486 3.141592.zip is no longer available
- Edited J1 silk label.
-To avoid risk of silk on pads I silked only the vias. prob woulda been fine but this wasn't hard and no doubts now.
-Moved that resistor that was bugging me
-Rotated one of the edge caps.
-Confirmed and fixed error in how the plotter was set up, those layers are checked now. for some reason it didn't check them automatically and I never noticed it.
-Added silk to vias of questionable proximity around the board as needed
-Unable to save as previous kicad file version as requested. sorry.
This pcb version is really nice, I'm liking where it is at. exciting!
-There are like 1,000 drc errors for silk screen now btw but it's fine. I knew that was gonna happen. shouldn't be an issue on physical object.
Feopia, are there any more concerns that I can address that you see on the physical part?
