Tillamook 266MHz and working L2 cache?
Reply 440 of 558, by Anonymous Coward
The "512k" thing is probably just some creative marketing. What they really meant is that there should be 512k L2 on your motherboard. This follows the same logic as writeback cache chips that PCChips engineers used as terminators to get the L1 cache to work.
Reply 441 of 558, by TRS-Eric
Sphere478 wrote on 2022-05-22, 22:28:
GRIFF wrote on 2022-04-26, 09:18:
Sphere478 wrote on 2022-04-25, 11:53:
This version goes on the tillamook pins its self between the socket and processor. The previous version went on the motherboard behind the socket.
Socket 5/7/SS7 (Processor Shim) Tweaker (Released)
Site don't permit me to send a private message.
Send me email please.
Check your PMs for my email
Update:
Hello, do you have more for buying/testing. I have a HOT-557 I want to try this in (I also can't PM yet)!
Reply 442 of 558, by Sphere478
Behold!
The attachment B6CC86F3-E948-4611-8004-32E5C2D876AD.jpeg is no longer available
What should I test first? What questions can I answer about it?
Sphere's PCB projects.
Reply 443 of 558, by TrashPanda
Sphere478 wrote on 2022-09-23, 02:39:
Behold!
The burning question is that silly 512k cache, I don’t believe for one second it has that on die but….my brain needs satisfaction.
So how about some tests to find out what that number is referring to 🤣
Reply 446 of 558, by TRS-Eric
I'm not able to get my tillamook 266 to see the 512k of cache on a Shuttle HOT-557 v1.5. My 233 mmx works fine with the 512k addon. I can use my motherboard's onboard 256k without issue on the 266 tillamook. Using the red l2 cache mod on the chip made the system unstable at 512k. Not sure what else to try. I took the red mod out and at least I get the 256k of l2 😀
Also if someone can find a 4.5x multiplayer modification or better that would be cool 😁
Reply 447 of 558, by Sphere478
Try brdy# and ads# mod?
May be a modo issue. Does it work on other cpus?
It doesn’t seem like a 4.5x is possible. I’m hoping to soon get a tillamook 300 and 366 (both fake, but one may have a real 300 inside)
Anyway, when I get it I hope to document 4.5x working and how it is actually done. Unfortunately I expect it will only prove that it was locked on the 266,233
Reply 450 of 558, by ChrisK
Sphere478 wrote on 2022-10-31, 10:55:
Where did you find this?
The paint job and the print really look horrible.
Have you already tested it?
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 451 of 558, by Nemo1985
I think it will be the old same tillamook 266, clearly a chinese forged cpu... Nice to have but not really useful
Reply 452 of 558, by Sphere478
Oh yeah, these are just novelties I am really curious if the 366 or the 300 has a actual 300 in it though (I’ll never be able to tell, unless… I am really hopeful that I can prove that a 4.5 X exists, if that shows up then. Boom! Definitely a real 300) unless intel used 75 fsb on them?
Reply 453 of 558, by Muzava
I have bought a Tillamook 266 a couples years ago and request a technician to modified.
It works on my Soyo SY-5EMA+ V1.0 (1MB Variant) and I tried in my Shuttle HOT-591P V2.0, but it doesn't like the Tillamook (it locks during post with L2 cache enabled).
I have a Jetway J-5TXA (430TX - ATX) that have VCore options of 2.04V and 2.14V, still have to test if it works in this motherboard.
Any ideas for the HOT-591P?
Reply 454 of 558, by Sphere478
Muzava wrote on 2022-11-20, 23:17:
I have bought a Tillamook 266 a couples years ago and request a technician to modified. […]
file.php?id=133154&mode=view
file.php?id=133109&mode=view
You can do this^
Or this>
file.php?id=139915&mode=view
See pcb projects in sig
Reply 455 of 558, by Muzava
Sphere478 wrote on 2022-11-21, 03:05:
https://www.vogons.org/download/file.php?id=133154&mode=view […]
You can do this^
Or this>
Mine is modded with the Red (just a wire), Yellow and Blue (just a wire), maybe it needs more mods to work the HOT-591P.
If I have time, I will test in the 430TX motherboard.
Reply 458 of 558, by Sphere478
Muzava wrote on 2022-11-21, 16:31:
Sphere478 wrote on 2022-11-21, 14:10:
Add yellow. That might do the trick
I have the Yellow.
Sorry, misread.
Vccdet is all that is left then.
