First post, by theelf
Hi, i need to manually power on a AT PS, dont have a connector or case
I have blue, brown, black and white colors. Someone remember what colors i need to connect to what other color?
thanks
Reply 3 of 7, by theelf
sorry any ideas? im working in a factory and im stuck in this problem
thanks
Reply 4 of 7, by Ryccardo
Generally blue to white and brown to black (that's IEC to American colors for neutral and live), but why guess when you can check? 😀
+Take a continuity tester (aka beep mode on a multimeter), put one wire on one of the outer pins of the socket for the power cable (that's often called IEC C14) and try the switch cables until you find the right wire (probably blue or brown);
+Repeat with the other - you now have the two wires coming from the wall;
+Now measure between the poles on the switch, you will find either nothing if it's off (then push it and try again) or 2 pairs if it's on;
+Connect the 2 wires you found in step 2 to one pair each (so, they must remain not connected to each other);
+The remaining 2 wires go to the 2 remaining pins, order should not matter at this point
Good luck!
Reply 5 of 7, by konc
Something tells me you don't even have a switch, and with these questions don't get me wrong but probably you shouldn't be trying this. Sorry if this sound stupid but I want to make sure you are aware of this: the cables that go to the switch of an AT PSU carry mains electricity.
Reply 6 of 7, by rasz_pl
theelf wrote on 2022-11-08, 17:08:
rasz_pl wrote on 2022-11-08, 17:03:
thanks
Still no idea.. do you know what color to what color?
there is a picture with colors on that page
Reply 7 of 7, by theelf
Ryccardo wrote on 2022-11-08, 17:42:
Generally blue to white and brown to black (that's IEC to American colors for neutral and live), but why guess when you can chec […]
Good luck!
THANKS!!! i follow your advices, and now everything works great. thanks
Problem solved
konc wrote on 2022-11-08, 17:51:
No switch, is a old industrial PSU inside a robot, and someone lost the front panel, where the button, leds, etc
rasz_pl wrote on 2022-11-08, 17:54:
thanks
But i dont have a switch
