Beepblaster 1.0, 2.0 Wavetable Module
First post, by Ulfenknulfen
Hi folks.
Beepblaster is on Github now.
https://github.com/Ulfenknulfen/Beepblaster-1.0-2.0
best regards
Paddy
🎵 Waveblaster Adaptor for IDE-HDD Swap Frames
🎧 Beepblaster 1.0, 2.0 Wavetable Module
🎶 Roland MT-32 Buffer overflow Hardware Fix
🕹️⌨🖱️USB HID Devices on PS/2 and Gameport.
Reply 1 of 86, by Tiido
What is the U2 ? I only see optrons in such package, and you don't need such a thing for a WB module since the MIDI signal on it is a TTL signal you're supposed to use directly.
Reply 2 of 86, by Ulfenknulfen
It is an optocoupler. I once learned 30 years ago that signaling devices can be
galvanically isolated as possible in order not to cause any damage in the event of an error.
It's a prototype Board. The final Version will be a different Layout.
best regards
Paddy
Reply 3 of 86, by dreamblaster
That's a nice idea, curious to hear how it sounds!
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 5 of 86, by darry
Cool concept. Curious to hear a demo.
Reply 6 of 86, by Tiido
In current case, a small value (100ohm is sufficient) current limit resistor will be enough in case you accidentally configure UART input as an output pin or such and have a signal fight happen due to it. The UART signals at WB header are 5Vpp TTL for both RX and TX lines, not a standard MIDI current loop (so you need to bear that in mind with the optocoupler in order not to burn out the diode).
Another important thing is the analog and digital grounds aspect, you cannot connect them together at the WB card without negatively (sometimes severely) affecting all of the sound in host card (digital return currents can create lovely thinkng noises into the sound from the ground loop that then gets generated). You may need a differential amplifer to cross the digital GND referenced MCU output into the analog ground side to have this problem properly taken care of. (I can draw up a working design if you'd like that ~)
I'm certainly curious to hear the results though, it should sound pretty fun ~
Reply 7 of 86, by Ulfenknulfen
Tiido wrote on 2022-07-21, 15:41:
Yep, and cheaper. You're right - i'll change it.
thanks a lot
Paddy
Reply 8 of 86, by Ulfenknulfen
Hello guys and thank you for your interest also via PM.
I've been asked several times why it does not go on here, so I explain it briefly here.
I'm from Germany, but I'm currently on holiday with my family on the Danish coast.
Everything was already packed, the retro PC for testing, soldering station, all parts about the beepblaster project,
yes I had even informed JLC-PCB, who kindly offered to beckon to me when the container ship passes by and then
drop off a dinghy with my boards, but I'll make it short - my wife did not play along! 😉
I hope for your understanding - next month we will continue.
best regads
Paddy
Reply 9 of 86, by Ulfenknulfen
Hi Guys 😀
The Beepblaster Projects is close finished.
Here you can hear the BTS (Beeptable Sound) Mode.
Have fun 😀
best regards
Paddy
Reply 10 of 86, by Ulfenknulfen
That is a short demo of the 2nd Mode of the Beepblaster.
BB Setting is more puristic 😀
best regards
Paddy
Reply 11 of 86, by SuperDeadite
I like it. I'll take one.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 13 of 86, by keropi
oh this is a huge improvement !
kudos Ulfenknulfen!!!
it is funny how we reached a point that now we want to hear "lo-fi" sounds instead of highest possible quality 🤣
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 14 of 86, by dreamblaster
Ulfenknulfen, I love it !!
Reply 15 of 86, by Ulfenknulfen
Hi Guys.
Beepblaster is now on Youtube.
https://www.youtube.com/user/B20A916VDOHC/videos
Thanks to PC-Sound-Legacy for supporting my Project!
best regards
Paddy
Reply 16 of 86, by ProcessID
My first thought upon listening to the audio is that it would make a fantastic lpt soundcard. I think it would pair well with PC speaker sound effects in games!
Reply 17 of 86, by dreamblaster
Paddy, it sounds great ! Congratulations.
Reply 18 of 86, by MN_Moody
Great project! Glad to put together a small group buy for my fellow Free Geek Twin Cities enthusiasts here in the US if you end up selling completed boards or kits.
Reply 19 of 86, by Ulfenknulfen
Hi Guys. The second Video is now Online (BTS vs. BB Mode):
https://www.youtube.com/watch?v=25EGgxQXoM4
best regards
Paddy
