First post, by GtiRacing
Hi I recently downloaded Test Drive III. As it needs a floppy, and i don't have one, im using DOSBox with the game, but the Sound is UGLY! I've tryed everything related to frameskip and cpu cycles but no solution. I've also modified sblaster as False, Tandy as False, Disney as False and PC Speaker as True in DOSBox.conf but my Speakers still emulating the sound, not the PC Speaker as i wanted. If anybody knows how can i get good sound with my speakers or ps speaker please help me!!!
Thanks!
NOTE: THE GAME DOESN?T WORK WITH VDMSOUND
Reply 1 of 9, by MiniMax
Rank Moderator
Moderator
I don't think DOSBox will use your real speaker, unless you somehow manage to convince Windows(?) that the PC-speaker is your default sound device.
_________________
Reply 2 of 9, by red_avatar
I thought the PC speaker emulation was pretty accurate? Actually less metallic than the real thing so it grates less.
Reply 3 of 9, by 5u3
Did you select PC speaker sound in the setup program that comes with the game?
Reply 4 of 9, by leileilol
Nope. Play Commander Keen 1-3 if you want to hear how inaccurate the pc speaker sounds.
Reply 5 of 9, by GtiRacing
No setup progeam comes with the game. The game executable is td2ega! OH AND IM SORRY THE PROBLEM IS WITH TEST DRIVE II THE DUEL!!!
Reply 6 of 9, by rcblanke
Confirmed, the same issue as for TD1 and Grand Prix: The Cycles. The engine noise does not sound as I remember it to.
Reply 7 of 9, by eL_PuSHeR
Confirmed as well for Test Drive. The engine sound effect sounds weird.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 9, by rcblanke
2007-07-15 18:36  c2woody
* src/hardware/pcspeaker.cpp: fix some pcspeaker mode
(high-frequency reloading); fixes Test Drive/Grand Prix Cycles
and similar
Awesome, thank you wd!!
Reply 9 of 9, by abyss
The pc speaker sounds are slightly off. I played jazz 1 on dosbox on the 500 mhz computer and for fun tried it on a 100 mhz computer with windows 95 and the program running on windows mode with pc speaker sounds and it sounds a bit different.
I personally prefer the dosbox pc speaker. You should use it on doom 1.
You can download a shareware version of the game. It sounds great with pc speaker.
