First post, by deksar
I'd like to ask about the stability for the VIA 4-in-1 chipset drivers on ASUS P4V8X-X (PT800 chipset) mainboard, for Windows 98SE.
What version should be the most appropriate one? As I read/heard, the latest/recent versions of VIA hyperion drivers are not really optimized for Windows 98SE.
What version do you prefer on Win98SE? Any idea, please?
My specs are: Pentium 4 - 1.80 Ghz - 1 x 256 MB DDR400 RAM - 120 GB IDE/PATA HDD.
Thanks.
Reply 1 of 11, by deksar
Well, by the way, it's not really only "As I heard", I actually have stability problems with VIA chipset drivers..
So any clue on 4-in-1 driver versions?
Reply 2 of 11, by VDNKh
The latest one is fine for stability on a PT880. 5.14 is the next go-to if you have any issues with it. Install the chipset and AGP drivers one at a time, you don't need IDE or RAID. The chipset installer will say it failed, but reboot it and all the drivers will appear. Unless you're using a PCIe GPU, you may run into this AGP Memory bug present in the 98 AGP drivers for the PT880 and K8T800. You should be able to downgrade your BIOS to fix it though.
Reply 3 of 11, by deksar
Hi VDNKh, thanks a lot for your reply.
I was reading the link you posted above.
Regarding the bug, I have Ati Radeon 9550 GPU - 128 Bit 256 MB, not an Nvidia one, does it differ here? And the chipset is PT800, not a PT880.
In order to downgrade, I plan to use afudos.exe under MS-DOS, I think I did that once, downgraded from 1009.008 Beta Version to 1008.
What's the suggested BIOS version? I guess it seems 1005 is the latest recommended one?
Here's my motherboard's BIOS list:
https://www.asus.com/supportonly/p4v8xx/helpdesk_bios/
Many thanks once again.
Reply 4 of 11, by VDNKh
deksar wrote on 2022-11-29, 18:30:
Hi VDNKh, thanks a lot for your reply. […]
Damn I'm getting dyslexic. The bug affects all AGP GPUs regardless of make. I actually don't know if that bug affects the PT800 chipset though. Try it without downgrading BIOS. You'll know if you have the bug or not when you open 3DMark01 and see under System Info that you have 0 bytes of AGP memory
Spoiler
file.php?id=132460&mode=view
Reply 5 of 11, by deksar
Okay, I think I have the same bug.
But it was disappeared after downgrading the BIOS, from 1009.008 to 1005.
Here are the screenshots;
3DMark01: Before downgrading the BIOS, total AGP memory was: 0 bytes.
3DMark01: After downgrading the BIOS, total AGP memory is as shown above.
GPU Card Properties Window: Current AGP Speed: was Disabled, it's now 8x Enabled after downgrade.
Dxdiag: "AGP Texture Acceleration" was Disabled, it's now Enabled after downgrade.
Reply 6 of 11, by VDNKh
deksar wrote on 2022-11-29, 19:49:
Yup that's the bug. I guess that's one more affected chipset to add to the list.
Reply 7 of 11, by pentiumspeed
What about the K8T800?
Cheers,
Great Northern aka Canada.
Reply 9 of 11, by pentiumspeed
VDNKh wrote on 2022-11-30, 18:13:
pentiumspeed wrote on 2022-11-29, 23:48:
Cheers,
Yes the bug is present there too. Downgrading the BIOS also fixes it.
But the board is not Asus, this one I have is a Fujitsu Siemens motherboard with K8T800 chipset, does this still have this bug?
Cheers,
Reply 10 of 11, by VDNKh
pentiumspeed wrote on 2022-11-30, 20:59:
Cheers,
Very likely as it affects all makes of motherboards as far as I know. It's trivial to check just by seeing if you have > 0 bytes of AGP memory in 3DMark01, or in DXDiag sometimes it will report AGP texture acceleration will be disabled too.
Reply 11 of 11, by scientistabe
Hi everyone, sorry for upping this thread, but have been toying around with a P4 VIA mobo (Soyo SY-P4PVT, with a P4 2.8GHZ and 1024MB DDR333) yesterday with various Radeon 9550 cards and it would lead to the same outcome on Windows XP with DXDIAG (when you test D3D) and 3DMark2001SE: It would crash anything beyond DX7 with an cryptic "Out of Memory" error, despite playing around the AGP settings on the aperture, AGP mode and so on. Switching from an ATI Radeon 9550 to an NVidia (Geforce 6600) solved the problem, but felt the performance was on par to previous bench (An Athlon64 3000+ with NF3 chipset was scoring a good 30% better on 3DMark2001SE).
