First post, by clb
Heya,
I just realized when testing on two different keyboards, a IBM Model M 1391411 and a KeyTronic one, that in Borland Turbo C++ 3.0 I cannot perform hold down the shift key and use the arrow keys to select lines of code on my MikroMikko 4TT m326 PC (386 SX 16MHz, 2MB RAM).
At first I thought it was a key rollover matrix thing, but then I tested the same two keyboards on my Cyrix 486 PC with the same Borland Turbo C++ 3.0, and there both keyboards do work and are able to select code lines with shift+arrows.
Anyone recall if there might be any DOS things that might affect, or BIOS items around something like this?
