Reply 140 of 193, by mmx_91
- Member
Sphere478 wrote on 2022-10-31, 21:42:You guys crack me up. Happy frankensteining!! Yes do keep us updated!!
Today I've managed to install one of your PCBs in my 'Frankestein' board and... it works!! 😀
I didn't have time until today to test it and also found that the TNT2 I wanted to test with was broken so had to order one of those chinese RageXL that I also wanted to try since I've watched Phil's video, so quite a good oportunity to spend 10€ for the sake of science hahaha.
Before soldering in I tested the video card and the board gave me indeed the 3beep code showing that no video display is installed, which also confirms what I've measured with the tester some weeks ago... the missing 3.3V signal. When soldering the PCB, I've also put a fuse inline with the 3.3V signal that comes from my also homemade AT-ATX adaptor (an automotive fuse holder I had lying around, it's just a test I know it's not the most appropiate setup xD), and soldered GND directly to the board input in the back of it.
The only pin I have not soldered is the 3.3V VSB, which in my board, it was not even connected to 5V, so I suppose it would have been safe, but I left it unconnected on purpose.
PD: you can also see some wires that correspond to a botched job I did in the past to repair the USB connector traces (I use USB keyboard and mouse). BE CAREFUL with that cause many of these old board do not have standard pinout for USB and you can burn something... as I did xD
