First post, by dr.zeissler
what Do you tink about these cards for a retro-build?
- GF3 ti200
- GF4 mx-440
- GF5 FX5500
These are DX8 cards (FX is DX9 but renders games like HL2 only in DX8)
What would you recommend and why?
Currently my System (AthlonXP 3000+ Barton core) is equipped with a GF3-ti200...I am thinking about getting a better passive-cooled or single-slot card with very silent cooling system.
It can't be a card higher than FX series and it has to be a nvidia based card.
Doc
Reply 1 of 43, by stef80
You can go for GF4 Ti and Zalman HP80D, if you can find it.
I would also consider Zalman VF700 or VF900, although not passive. FX5900(XT) and VF900 would probably be top combo.
Reply 2 of 43, by leonardo
dr.zeissler wrote on 2023-01-11, 11:05:
Hi, […]
- GF3 ti200
- GF4 mx-440
- GF5 FX5500
Doc
I'm running a Ti200 in my P3 1 GHz system and whilst the card did not come with a fan, it certainly ran hot enough that I wanted to add one. If you go for a good 60x60 on the original heatsink, it won't make a ton of noise and is quite easy to implement.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 3 of 43, by dr.zeissler
Reply 4 of 43, by stef80
GF3 ti200 then
Reply 5 of 43, by zyga64
Hi, […]
- GF3 ti200
- GF4 mx-440
- GF5 FX5500
Doc
MX440 is actually DX7 card (in hardware). In its 128bit memory version is probably faster than FX5500 for DX7 stuff (hardware T'n'L).
GF3 ti200 is best of this three (solid DX7/DX8 performer).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 6 of 43, by dr.zeissler
Then I will stay with GF3. Thx!
Reply 8 of 43, by The Serpent Rider
Passive GF3 Ti200 is a bad idea, unless it's a large third party heatsink.
Reply 9 of 43, by dr.zeissler
This is how it looks like.
Reply 10 of 43, by kolderman
That case has poor airflow tho and is cramped. I would not do that to a valuable card, maybe a MX440 or something.
Reply 11 of 43, by Putas
If the FX 5500 is 128-bit, I will choose her for similar performance but with more options.
Reply 12 of 43, by The Serpent Rider
dr.zeissler wrote on 2023-01-11, 18:26:
You'll just ruin it eventually.
Reply 13 of 43, by iraito
That can't run passive, even a passive low profile GPU would struggle if the rest of the system gets too hot, if anything i would mod the case to improve and add airflow.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 14 of 43, by pentiumspeed
Does the top cover have grille on it's side where GPU is located?
Cheers,
Great Northern aka Canada.
Reply 15 of 43, by dr.zeissler
pentiumspeed wrote on 2023-01-11, 21:00:
Cheers,
Yes.
Reply 16 of 43, by pentiumspeed
Run some time then promptly feel the video card's heatsink?
Cheers,
Reply 17 of 43, by Garrett W
Can't you install a small, silent Noctua fan on the card? They are a bit expensive, but they are very silent, I've seen people mod Playstation 2 consoles with said fans.
Reply 18 of 43, by dr.zeissler
Garrett W wrote on 2023-01-11, 21:24:
perhaps...but don't know how to mount it.
Reply 19 of 43, by The Serpent Rider
ZIPTIES 🤣
