Reply 220 of 1301, by appiah4
True, and apologies if I disrespected anyone. Same goes to you as well marmes and 640k!enough.
Reply 221 of 1301, by keropi
too late
-18565 points to appiah4 !!!
Reply 222 of 1301, by Vanessaira
That is um, a lot of points. 🤣
An Analog Girl in a Digital World
Reply 224 of 1301, by appiah4
Vanessaira wrote on 2023-02-07, 21:34:
You underestimate my points..
Reply 226 of 1301, by RetroBoogie
Congrats on the launch everyone! Took my eyes off this for a little bit and missed the first wave, but signed up for the second. Thanks to all of you for doing things like this for the scene.
Reply 227 of 1301, by KuroHouou
Any recommendation on the RAM SIMM that would work well for this?
Reply 228 of 1301, by KuroHouou
Has anyone else noticed when using OPL 3 in Windows 98 with a media player that it sounds very different then running OPL3 in a DOS Window while in Windows 98? I was just noticing my Doom midi tracks sound very different when played directly in a media player like windows media player or winamp in 98 vs actually playing the game in a DOS window while in Windows 98. I don't know how to explain the sound exactly but you can clearly hear a difference. Even when comparing midi's like passport.mid or canyon.mid to OPL 3 versions I have heard online. Something seems to be off with the OPL3 sound directly in Windows 98... I have tried both initializing orphinit and without thinking maybe it was something in that screwing with it but that isn't the case as it sounds the same regardless of what I do with orphinit.
Reply 229 of 1301, by Tiido
DOS games use their own instruments and they are not the same as what FM MIDI driver in Windows uses.
Reply 230 of 1301, by Kahenraz
I thought that FM was FM. It's General MIDI which has instruments.
Reply 231 of 1301, by KuroHouou
Just tried to run the doom midi file in true DOS mode using dosmid.exe (not in windows DOS mode although I tested there and it had the same effect) and it also sounded weirder and not even like playing it in Windows Media Player or Winamp. Dosmid reported it was using OPL3. I thought for sure in DOS itself the midi would playback and sound like the actual game.. but I guess this is really how it is. Found another thread on here confirming what Tiido said, Doom 2 MIDI OPL3 issue. Very interesting, learn something new every day, OPL3 "can't" be used to play generic Midi files, or I should say, at least not in a way that would sound like they do in an actual game. Learn something new everyday.
Reply 232 of 1301, by Tiido
FM has no built in instrument bank, just a big handful of parameters which make up the sound needed, all of which is under programmer/musician control. Every game and whatever else software writes their own set of parameters, often found via experimentation, to approximate the instruments in MIDI devices, when source data is MIDI based like with many DOS games. A number of games are OPL "native" and can sound good as they're not trying to shoehorn in a spec that the chip is not exactly capable of reproducing 🤣.
Reply 233 of 1301, by dj_pirtu
Missed the first batch but order is in for the second!
I have many GUS cards, MAX and Classic in almost all of my retro-PC's but never got Extreme and prices for those are unbearable.
Reply 234 of 1301, by dionb
I have a cute use case for this card - a supercompact system with small (but standard-layout) AT motherboard with no onboard I/O, a riser and two ISA slots on opposite sides. Total height is just 5cm. I have it at work for light relaxation during breaks.
Currently it has a multi I/O card in the one slot and VGA in the other, but i've found an ISA VGA+I/O combi card and was intending to put a sound card in the other slot anyway. Currently have a simple SB2.0 clone, but would love to see colleagues amazed by everything the Orpheus II can do 😉
Reply 235 of 1301, by aegisk
KuroHouou wrote on 2023-02-08, 14:36:
Good question. Would be great to be able to know beforehand if I need to source memory modules or if I already have some in my stash.
Reply 236 of 1301, by kalgon
dionb wrote on 2023-02-09, 09:01:
Can you post a picture of it?
Reply 237 of 1301, by florian3
aegisk wrote on 2023-02-09, 13:29:
Should be similar to the ARGUS card (check that thread), that accepts pretty much any FPM or EDO RAM that is 5V and should be 70ns or faster. I'm using some cheap single rank 16MB FPM that I bought on ebay. I also tried dual-rank 32MB EDO and it works fine (but only uses 16MB).
Reply 238 of 1301, by Kahenraz
Is there any way to validate them through usage? Or is it an all-or-nothing kind of thing?
Reply 239 of 1301, by Marmes
5v 16mb fpm 72pin simm is what I use.
Works good.
