Reply 48180 of 57073, by Ozzuneoj
- l33t
TheAbandonwareGuy wrote on 2023-02-25, 03:49:Bought an untested (probably genuinely, seller seems to mostly deal in antiques and knick knacks) GeForce FX5700VE for $30
We'll see how that goes. Probably poorly based on prior experience with GeForce FX series cards.
If it's a loose card I'd say there's about a 90% chance that it has some damage to the SMD components on the back. It will just be a matter of if it's anything vital or if it's just some EMI filters or something.
I managed to snag a Gainward FX 5700 Ultra, a BFG 5700 Ultra and a BFG 5500 PCI from the same seller and all three had at least one damaged component on the back. Thankfully, the 5700 Ultras both run fine. They have an almost identical layout, so I was able to use a multimeter to check the broken components on either one, and they appear to both be filters of some kind. Sadly, the 5500 is totally dead. The two components broken on that must have been vital.
Also got a 3dlabs Wildcat VP990 Pro and it has a broken component near one of the DVI connectors... hopefully it's also nothing vital. I haven't tested it yet... the more I think about it, I have gotten a TON of hardware with PCB or SMD damage lately. I can think of 4-5 other somewhat decent cards in addition to the ones above. 🙁
So many people just didn't take care of this stuff over the years and left it all thrashing around loose in a box. I love it when sellers are so clueless about this (and physics apparently) that they take photos of heavy\bulky cards stacked and then they slide them around in all different orientations for their pictures, sometimes with the brackets perched on the backs of other cards in an attempt to look fancy. I mean... DUH. It'd be like a used car dealership leaning or stacking all of their cars on top of each other on the lot to get attention. 🤦
