First post, by Pingaloka
Hello fellow vogoners!
I'm putting up together a new build. I'm going to use a Socket 7 AT motherboard and a Pentium 200MMX CPU.
I like my builds to be practical but also to mantain an old school feel. I also always use CRT monitors as that is a must for me!
What I have so far:
1. Various Socket 7 AT motherboards.
I don't like ATX factor when it comes to MS-DOS early Windows 95 gaming.
2. Various AT Computer cases.
3. The CPU
Going for an Intel 200MMX. Why? I would like to be able to play up to games like Blood and also be able to slow down the computer to play Graphic Adventures typical of the 386 era.
5. Various Video cards.
I won't be doing any 3D so no voodoo fancy stuff here. I'll probably use an S3 Trio 64V+
6. RAM: 16MB no more no less
7. Audio
Right now I have 3 sound cards but I would like to get the new Orpheus Lite eventually.
As for MIDI I'm getting a WP32 McCake from Serdashop!! A really cool acesory for MT-32 and General Midi music.
8. Storage
I'll be using a PCMCIA Reader Card 3.5" Bay and have bought a PCMCIA to CF adapter so I can use 1 x 2GB CF for MS-DOS 6.22 and another 1 x 2GB CF for Windows 95
9.Keyboard and Mouse.
I'm going to use PS/2 keyboard and a optical Mouse.
So guys, I would love to hear your opinions on the different options I could use to build this new All-in-one Retro Computer. Help me out here!
First let's look at the several Socket 7 Boards I have right now at my disposal:
MSI MS-5130
Chipset
SiS 5596/5513 ((Genesis) Pentium PCI Chipset)
Chipset parts
SiS 5513 (PSIO)
SiS 5596
Audio chips
ESS AudioDrive (ES1868F)
Video chips
SiS 5596 (5596)
Max VRAM
2MB
Supported RAM size
512 MB
Supported RAM types
72-pin FPM, 72-pin EDO
CPU socket
Socket 7 (PGA321)
CPU platforms
Pentium (P54)
Pentium MMX (P55)
This board had 2 interesting things. It has 2 x PS/2 connectors already integrated in the motherboard. It has also an ESS Audio integrated chip and a VGA SIS integrated chip. I suposse I need some kind of adapter cable that goes from the connector on the motherboard to the back of the computer to take advantage of these?
FIC PT-2003
Chipset
Intel 430FX (PCIset FX Triton I)
Chipset parts
Intel 82437FX (TSC)
Intel 82371FB (PIIX)
Intel 82438FX (TDP)
Supported RAM size
128 MB
CPU socket
Socket 7 (PGA321)
CPU platform
Pentium (P54)
Supported FSB speeds
50MHz, 60MHz, 66MHz
Cache
256 KB , 512 KB
Zida Tomato 5DHX Rev. 1.2
Can't find much info about this one.
MSI MS5117 Ver 2.
Chipset
VIA VT82C570M (Apollo Master, Green Pentium/P54C)
Chipset parts
VIA VT82C575M
VIA VT82C576M
VIA VT82C577M
Supported RAM size
512 MB
Supported RAM type
72-pin FPM
CPU socket
Socket 7 (PGA321)
CPU platform
Pentium (P54)
50MHz, 60MHz, 66MHz
Cache
256 KB , 512 KB , 1 MB
Shuttle Spacewalker 591P Ver 3.1
VIA APOLLO MVP3 chipset.
Chipset
VIA VT82C598MVP
VIA VT82C586B
Form Factor
AT
Processor
Socket 7
Supports AMD K6-2, K6-3, K6, K5
Intel Pentium, Pentium MMX
Expansion Slot
1 x AGP (2x AGP)
3 x PCI
3 x ISA
Memory
2 x DIMM
2 x SIMM
Support PC100 SDRAM
Vintage Trigear L-9650-8
No much info about this one.
So what do you guys think about this boards? Which one would choose if you were to build your own Socket 7 Computer?
I'll save some posts in order to later show the different cases I have, the video cards and the sound cards.
To be continued....
Reply 3 of 48, by the3dfxdude
I'd start with the Shuttle Spacewalker 591P Ver 3.1 and get that going first. The others I'd test and see what I can do with them and how they run. But just on what you presented, I think that is what I'd run an MMX on.
Reply 4 of 48, by Pingaloka
the3dfxdude wrote on 2023-03-05, 22:41:
Just realised this one has a AGP slot also!
I need to check if It has a ps/2 mouse header somewhere.
It seems like this board is midway between AT and ATX form factor.
Reply 5 of 48, by ediflorianUS
So it's a PC , not a All in one pc like the Vintage Computer All-in-One Panasonic CF-55 ... If you go with AGP 2X you can get 4x gpu's also to work, TI4600(or quadro version) my favourite. I have K6's and used a long time older sk7 IBM CPU (233 i think) probably faster the IBM CPU than most K6 or Intel , so if you find one test one. as for ram.... if you got SDR on that board max it out , why not , dos uses only as much as it need's to aniway's.
My 80486-S i66 Project
Reply 6 of 48, by Pingaloka
ediflorianUS wrote on 2023-03-06, 14:16:
All-in-one might be badly expressed. What I meant is that this build should be able to slow down as a 386 and as fast as a 200MMX to be able to play a wide range of games.
Reply 7 of 48, by the3dfxdude
Pingaloka wrote on 2023-03-06, 07:03:
Just realised this one has a AGP slot also! I need to check if It has a ps/2 mouse header somewhere. […]
It can fit in many cases of both types of the time. Even the quintessential 430tx chipset for the mmx, you could buy boards that had both connectors. I think I still have one that way. Since you have selected an AT case, you'll be fine with either power supply. Which can be nice. Many boards have ps/2 as well, which yours does. I think some have usb too. So the shuttle board has alot of flexibility, you may be able to get it running quickly.
Since you do not have a 430tx in your list, the best ones seem to be the via chips, with the shuttle board seems like the correct fit for the mmx. The other one has a barrel battery to deal with. The other thing you got to check on here, is most of the rest of these you do not indicate if they explicitly support p55c, for the mmx's dual voltage. They may indeed be too old. Which means you would be looking for an interposer or overdrive to deal with that. For that SiS one, it may be an odd fit for an AT case, and you may not have the riser for the sound card.
Reply 8 of 48, by gen_angry
The shuttle is what I would probably go with. It's a super socket 7 board so you'd have the option to clock up to a K6-2/3 if you wanted to in the future, that AGP slot sure is pretty, and ATX compatibility.
Downside from what I can see is that the boards layout is pretty terrible due to the CPU socket's location. Doesn't look like larger length PCI cards will work on it so may want to check card length. There are shorter length Trios that would probably work (I had a Phoenix model that barely clears the PCI slot itself but my current Cardex would likely not fit there. Voodoos would entirely likely be out). If you wanted to utilize the AGP slot, there are AGP versions of VIRGE cards (they use the same 2D graphic core as a Trio). Here is a good chart for DOS VGA compatibility across several brands: https://gona.mactar.hu/DOS_TESTS/
If that's a deal breaker for you, the tomato or the FIC boards are likely my #2. Both are pretty similar so either works. More info on the tomato here: https://theretroweb.com/motherboards/s/zida-5dhx-ver.-1.20
The others I don't like because of battery reasons (MSI MS5117 Ver 2./Vintage Trigear L-9650-8) or card length reasons like the shuttle but not having the SS7 advantage (MSI MS-5130).
Reply 9 of 48, by Sphere478
Well, the best one there is probably the mvp3
You could run your pentium 200 at 100mhz x2 and use agp cards.
Your upgrade options for cpu are also easier compared to some of the onthers.
Sphere's PCB projects.
Reply 10 of 48, by the3dfxdude
gen_angry wrote on 2023-03-06, 16:29:
Ah, so the tomato has 430hx triton ii, so it has MMX support. Also, it looks like it has USB and ps/2 😀 The FIC seems to be 430fx triton i, so no mmx out of box.
Reply 11 of 48, by BitWrangler
Pingaloka wrote on 2023-03-05, 21:58:
8. Storage I'll be using a PCMCIA Reader Card 3.5" Bay and have bought a PCMCIA to CF adapter so I can use 1 x 2GB CF for MS-DOS […]
8. Storage
Kudos on the "legit" era plausible flash storage. Every time someone says "but you can't do it authentic blah blah" I say. Yes you can, PCMCIA, and ATA Flash cards if you get one cheap or have the coin, but use CF adapters as stand ins. I've got a setup I'm waiting for the right system for, plus my "token" real PCMCIA flash card I've owned for decades (Only 2MB so it can't get Doom on, booo) Keep meaning to order CF adapters, but keep forgetting.
Reply 12 of 48, by BitWrangler
the3dfxdude wrote on 2023-03-06, 18:35:
Neither of those look like they have split core voltage, so would be limited to P54 (non-MMX)
Reply 13 of 48, by the3dfxdude
BitWrangler wrote on 2023-03-06, 19:01:
Yes, if u26/28? on the tomato is the voltage regulator, it's missing, and also the jumpers are hardwired to 3.3v.
Reply 14 of 48, by Pingaloka
the3dfxdude wrote on 2023-03-06, 21:02:
The Zida Tomato 5DHX Rev. 1.2 seems to be compatible with MMX CPUs, also the MSI MS-5130 but that board can be a bit complicated to work with because of the PS/2 keyboard / Mouse headers location, I would have to check with the AT case I'll be using.
The MSI MS5117 doesn't seem to be able to handle MMX CPUs, plus it has a barrel battery although that one you guys see is new as I changed it.
TheTrigear L-9650-8 nobody has voted for and it has the hideous battery system. IT's the first time I see this brand.
So, this leaves me with 2 options right now:
1. Zida Tomato 5DHX Rev. 1.2
2. Shuttle Spacewalker 591P Ver 3.1
They can both do MMX, and both have PS/2 Mouse headers.
The Shutte Spacewalker can do AGP but I think I'll stick with a S3 Trio64+ PCI or Virge DX PCI graphics card to be honest. Don't see any advantage for DOS gaming using an AGP graphics card appart from maybe capturing video purposes or playing 3D games on W95 / W98, which I'm not. Nevertheless I'm inclined more towards the The Shutte Spacewalker motherboards as it has more upgrade options plus the VIA chipset is more advanced than the 5DHX from the Zida Tomato board?
Question: Why do people prefer using an ATX PSU reather than an AT PSU? Is it because you can buy and use a new ATX one and normally they are not as old? That is a pretty good reason already. They are more reliable?
Question 2: Any advantages using an AGP graphic card on Ms-DOS and W95? Any recommended model?
Thanks for the comments guys!
Reply 15 of 48, by gen_angry
Good catch, I didn't even think about the split voltage thing. In that case, would either have to stick with a board that supports it natively, go with one of those powerleap things, or settle for a 200 non MMX.
Pingaloka wrote on 2023-03-06, 21:38:
The Zida Tomato 5DHX Rev. 1.2 seems to be compatible with MMX CPUs, also the MSI MS-5130 but that board can be a bit complicated […]
Answer 1 - newer supplies are more reliable in general. As power supplies age, the capacitors in them can dry out and cause issues. I've had a number of older grey-box supplies just suddenly die and take out parts with them over the years. Not to mention, they're far more efficient than they used to be - even 80% power efficiency was unheard of back then.
Downside is, PSUs today are designed around mostly 12v where as systems in the past were designed around 3.3v and 5v. So you'll have to be a bit choosy on which modern supplies that you use, pay attention to the spec sheets.
Answer 2 - for DOS? No real advantage aside from keeping a PCI slot free and well, if you have it you might as well use it. It matters more for later Windows 3D stuff. Downside would be Win 3.1 driver support due to the newer cards mostly if you care about that any. For DOS and pre Pentium II builds, PCI is perfectly fine for graphics.
Reply 16 of 48, by Sphere478
Agp gfx cards seem to have more and cheaper options for faster models. Like radeon 7000-9000 series, geforce 2-4 series. Would be good bets.
Note though that these first gen agp slots sometimes didn’t play nice with all cards.
I have a radeon 9000 though that plays well in most of my ss7 stuff. Some of my ss7 mobos will even run my 9800 pro. But not all.
A radeon 9250, quadro2, gf3, radeon 7500 agp would be really nice and affordable options here.
The dos gurus may have different recommendations though. I mostly do windows stuff with my hardware.
Reply 17 of 48, by Pingaloka
gen_angry wrote on 2023-03-06, 21:59:
Good catch, I didn't even think about the split voltage thing. In that case, would either have to stick with a board that suppor […]
I'm looking around for an ATX PSU but all of them seem to do 12V+, they do actually sell new power supplies compatible with super socket 7 boards? Do they actually fit in an AT Case?
Reply 18 of 48, by Sphere478
Pingaloka wrote on 2023-03-07, 06:51:
I use new atx psus all the time with ss7 stuff.
No -5v
And extra 4 pins.
But that’s not usually a problem.
ATX to AT pico Adapter! + Fan Headers Soft on/off, -5v, and 3.3v (Released)
There is also this
Reply 19 of 48, by Pingaloka
Sphere478 wrote on 2023-03-07, 07:33:
I use new atx psus all the time with ss7 stuff. […]
No -5v
And extra 4 pins.
There is also this
The -5V is only necessary for some boards such as the Sound Blaster 2.0 correct?
