Reply 40 of 328, by douglar
- l33t
Thanks for those explanations. Great stuff.
Here's the cards I got lined up to test:
- Acculogic
Chip: ADI/2
Board: sIDE-4/VL rev C
Fccid: IIV0041900A00
https://arvutimuuseum.ee/th99/c/A-B/20956.htm (but mine is Rev C and has more jumpers)
-------------------------------------------- - Atronics
Board: ATI-IDEAL VL-CACHE
Fccid: E8M5IG2015P
https://arvutimuuseum.ee/th99/c/A-B/20873.htm
-------------------------------------------- - Atlantic Components
Chip: Lion 3+
Board: Lion 3+ VL IDE I/O
Fccid: LTNAYCOMP-9401
http://vogonsdrivers.com/getfile.php?fileid=1 … menustate=56,55
-------------------------------------------- - Biostar
Chip: PDC2023C
Board: IODE-3292PUV-C
Fccid: I27IODE-3292PUV
https://arvutimuuseum.ee/th99/c/U-Z/20760.htm
-------------------------------------------- - Holtek Microelectronics
Chip: HT6560B
Board: VIO3A-V1.1
Fccid: LCMVIO-3A
https://web.archive.org/web/19970129011353/ht … um/PC/6560a.htm
-------------------------------------------- - Quantum Designs
Chip: Vision 6500
Board: QD6500a v3.011
Fccid: KDE6500VLIDE
https://arvutimuuseum.ee/th99/c/P-R/20752.htm
Chip: Vision 6580
Board: QD6580w PCB 1.0
Fccid: KDE6500VLIDE (Same FCCid on PCB, but different board)
https://arvutimuuseum.ee/th99/c/P-R/20751.htm
-------------------------------------------- - UMC
Chip: UM8672F
Board: FSIOL-UC2C
Fccid: HBQUMC8237D01
https://archive.org/details/fsioluc2cfloppy Archive.org
I was going to test using a WinTech MV008 mobo that I found recently. Seemed like a great choice because it supports 386 & 486 chips, but the BIOS been real touchy about attaching drives > 512MB even with XUB or MR BIOS. I can get some to work if I use SIIG Advanced BIOS and EZ drive together, but that was weird. I have a couple other board to try if I can't get this working, but all in all it chewed up my morning. I suppose I could switch to drives < 528MB for testing.
So far I collected dos drivers for Lion 3+ and UM8672F.
I'm looking for drivers for the ADI/2, Atronics, Holtek, Promise and Vision chips. Any uploads or links would be appreciated.
I suppose I could try to use the XUB Advanced support for the Promise and Vision chips if nothing else turns up.
