First post, by marold
Hello!
I have a problem with the German version of Microprose's Grand Prix 2 and therefore kindly ask for your help. My DOSBOX version is 0.70, the recommended information about my system are listed below - as far as I could figure out what they mean 😊
The problem is as follows:
In fact I am able to start the game with DOSBOX by simply mounting the CD-drive. It works and is playable (except for the sound), but the big problem is that I can't save the game, because the savegame-option refers to the directory on the hard disk, which logically doesn't exist when the cd-drive is mounted. Then I referred to your FAQs, copied the whole CD in a directory on my hard disk and started the game by using this very complicated mounting-command (in my case: mount d C:\gp2 -t cdrom -GP2GERMAN). Again, it did work, but again I wasn't able to save any game information. Also moving the savegame-dir into the directory which is mounted as "fake CD" didn't help. Is there any way to make the game write to its savegame-directory???
Thanks in advance for your help.
Yours sincerely, Manu from Austria
Information about my system:
Microsoft Windows XP, Home Edition, Version 2002, Service Pack 2
processor 1500 MHz
1,50 GHz, 496 MB RAM
Intel(R) 82852/82855 GM/GME graphics controller
Intel 82801DBM ICH4 - M - AC'97 Audio Controller [B-1]
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
It should be something like
mount c c:\oldstuff
mount d f:\ -t cdrom -label WHATEVER
Note there's no -t cdrom for the C: mounting, otherwise the mounted
directory can't be written to.
Then install the game from the cdrom to the (mounted) C: drive,
so installation and save game files should go into c:\oldstuff
Reply 2 of 2, by marold
Thanks a lot, you are great!!!
Now it works perfectly.
Greetings, Manu
