First post, by Vaelor
- Newbie
Hi all, I'm having a problem with DOSBox which is bugging the hell out of me. Whenever I run it in full screen mode (which is always, I have no use for windowed mode when gaming!), the top quarter inch or so of the display is pushed off the top of the screen. It seems to be stretched, not shifted, as the bottom of the display appears to be where it should be.
Is there some kind of setting, configuration or tweak I can use to make DOSBox fit the screen properly in full screen mode? I'm dying to get back into my DOS games but I can't play like this.
Any info anybody can give me would be hugely appreciated, thanks in advance!
Vaelor's Keep
