First post, by SETBLASTER
- Member
I have been trying find information about what is the fastest possible voodoo 5 5500 build. Since we are limited to the AGP speed of the card, we need to find trully supported motherboards with universal AGP.
Some forums mention the VIA KT333 chipset for a fast voodoo 5 5500 experience. Not sure why KT333 is not something easy to find here, there are however more motherboards with via KT266 found everywhere.
This is as far as you can go with VIA because i think back then they used universal AGP and later on they started using AGP 8x slots.
But my question is more on the Pentium 4 side, there is not much info on a voodoo5 used with a pentium4.
And Pentium4 was a big part of the market. For example they even used SiS chipsets with pentium 4 that had universal AGP slots, like the Asus p4S533-E
which supports up to pentium4 2.8ghz.
or KT333 via is still faster?
