First post, by Jackhead
My first PC was a 486DX2 66 and so i start this build to get some memories back.
It was in the same case i used here.
Back in the days i was wondering what Roland is on sound option. Today i really love Midi Sound in all the different ways.
So Dos and Midi is my target here.
I try to keep anything authentic as i can, beside from the PSU and the CF.
Still had some small stuff to change, the L2Cache upgrade to 1MB and with that also 64MB RAM.
The parts i used so far:
MB: ASUS VL/I-486SV2GX4 Rev 2.0 with latest bios and L2 WB Fix, 1MB L2 (L1+L2 WB)
PSU: be quiet! SYSTEM POWER 9 400W CM
CPU: AMD A5x86 X5 ADZ 133MHz @160MHz
RAM: FPM 4x 16MB 60ns running WS=0
SPU: Creative Soundblaster Pro 2.0 CT1600 REV 3 , Gravis Ultrasound ACE 1MB
Midi: Roland MPU-401AT + Yucatan FX Wavetable
Midi Canvas: Roland MT-32, CM-32L, SC-88 Pro
CHiLL V: E-Wave, Q-Wave, McFly, Yamaha DB-50XG
GPU: Tseng ET4000W32P 2MB FRAM VLB
I/O: Promise EIDE 2300 plus VLB 32gb msata-ide
HDD: Startec IDE-CF Adapter with 4GB Transend CF
CD-Rom: Mitsumi Quad Speed
Floppys: 3,5" 1,44MB Teac, 5,25" 1,2MB Teac
OS: DOS 6.22 + Win 3.11
I recapped anything with nichicons. For the Audio i used the muse fine gold caps. Ordered also some sticker from Geekenspiel.
Plan do samples from FM and Midi to my eurorack. Also of corse gaming.
Here some Pics:
634.72 KiB
650.66 KiB
1.23 MiB
1.17 MiB
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 16, by Jackhead
As Display i use a Sony 21" CRT Trinitron E530 with a Audioengine 2+ active speaker setup:
1.14 MiB
Reply 2 of 16, by Joseph_Joestar
Jackhead wrote on 2023-03-21, 17:18:
That monitor looks fantastic! Not sure if those speakers are shielded or not, but I would move them a bit further away from the screen, just in case.
Anyway, great build!
Reply 3 of 16, by Jackhead
It is, i mod the firmware with the sony factory software to adjust some things.
But the Sonys have this color adjustment feature in OSD what did most of the job, pretty good!
Some more Nichicon Muse OPL3 love that caps:
1.65 MiB
1.41 MiB
Reply 4 of 16, by badmojo
What a spectacular build! Recapping isn't much fun but what a great result - I've done the same with my sound card and am note sure if I can hear any difference, but it sure makes me feel good.
Thanks for sharing 👍
Reply 6 of 16, by mockingbird
I see you're also of the rare breed that preemptively re-caps all his old hardware, even if nothing's wrong with it... One thing you missed though are the tantalums on the motherboard... Tantalums have a finite lifetime, and tend explode after several decades. But Asus used good ones, and you can still get the exact replacements (I think they're Kemet, I don't recall precisely).
(Decommissioned:)
Reply 7 of 16, by Jackhead
Some updates on the unit.
I upgraded the system to 64MB RAM with 1MB L2 Cache. Also add a hdd clicker and the CT1600 got a Ultrasound ACE as partner.
The Ace is upgraded to 1MB and installed with pro patches 1.61 lite.
924.75 KiB
572.19 KiB
Reply 8 of 16, by PC-Engineer
A very nice system compilation. I would bet anybody here would be jealous of it. The SV2GX4 (Rev 2.x) is a dream for a Socket 3 VLB 486. Also your soundcard combination leaves nothing to be desired.
For my taste an Am5x86 is rather a low-cost Pentium alternative from the year 1995/96 and does not trigger a high-end want to have with me. I would rather put an iDX4 100 (1994) in it. It’s easy to overclock to 120MHz if necessary.
The ET4000W32 from 1993 doesn't quite fit into the high-end feeling for me either. What do you think of a S3 Vision? The 864/868 cards offer almost the same performance as the ET4000W32 under DOS with even better compatibility, but have the more modern functionality in Windows and offer better refresh rates there. If the focus is even more on Windows, then the Vision 964/968 is also worth a look, they are even available (but very rare) with 4MB VRAM and excellent DACs, which would make your 21" CRT very happy. The 864/964 are chips from 1994 and would be a nice fit for a high end 486 in it’s best year.
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 9 of 16, by bloodem
Awesome build! I'm very jealous! 😁
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 10 of 16, by Jackhead
PC-Engineer wrote on 2023-04-30, 06:30:
Interesting point. I will have a look and give it a try if i can find something. Thanks! Has the 964/968 also vesa 2.0 support? Or is vesa 2.0 not a thing with vlb?
I mean i know that i cant run high resolutions, i also dont really want it. But you notice the problems with games support ves 2.0. For example Shadowwarrior.
Reply 11 of 16, by PC-Engineer
None of these cards has a VESA 2.0 BIOS. But there is a little tool S3VBE, which ads VBE 2.0 support to S3 Vision cards.
S3VBEFIX - PC\MS-DOS TSR fix for S3 VESA 2.0 video BIOS
http://www.vogonsdrivers.com/getfile.php?fileid=440
And an interesting german site
http://stephan.win31.de/elsa1k2k.htm
Reply 12 of 16, by Jackhead
What about a S3 924? I dont find much info about it. It has also up to 4MB with 24/32bit true color mode.
Reply 13 of 16, by PC-Engineer
NO! It’s a Chip from 1992 for ISA. The successor S3 928 is much better and with VLB/PCI/EISA Support, but even slower than the Vision Chips.
If you are searching for cards with S3 Vision, you should look for their names from the vendor like: Miro Crystal 20SD, ELSA Winner 1000 Pro, Spea Mirage P64, Diamond Stealth 64, Genoa Phantom 64, Orchid Fahrenheit 64, Number Nine GXE64, …
https://www.vogonswiki.com/index.php/VESA_Local_Bus
There are very few cards with 4MB. I have in mind the Diamond Stealth 64 (Video) VRAM, ELSA Winner 2000 Pro and the Miro Crystal 40SV
The user Madao developed a S3 968 VLB card with 4MB VRAM. Maybe he has an additional card for you available.
Reply 14 of 16, by Jackhead
I checked it, but i see not really a benefit for me. I just run dos 320x200 with this setup. When the cards able me playing also games with 640x480 than i would say its worth. But i rare use windows. And i think with higher resolutions my cpu is than the problem too(with games).Correct me when im wrong.
Reply 15 of 16, by PC-Engineer
For DOS @320x240 your ET4000W32 is fine. Maybe UNIVBE can support VBE2.0 BIOS for your card and you are lucky with it, even in SVGA DOS modes.
Reply 16 of 16, by Jackhead
I update my ide controller to a promise eide2300 plus. Really nice one it can handle 32gb. I run a m-sata mlc with it dma @ 12MB/s
1.54 MiB
