First post, by doublebuffer
I am setting up my first vintage PC and now I am wondering how I should connect the peripherals. The computer has this weird connector for mouse (see the photo) I have no idea what it is, but for keyboard it has DIN which I can adapt to PS2.
But there in start the questions. As I see I have these options:
1) Get an old keyboard with PS2 and a serial mouse. Downside: most likely not-the-best rubbery keys and ball mouse. If they break the same process of sourcing parts again. Can be expensive.
2) Somehow adapt modern USB peripherals. Downside: is it even possible? Some USB keyboards support PS2, but they are probably not manufactured anymore./
3) Build diy a keyboard, with new switches but old type of connector. Downside: a lot of work.
How have you guys solved this?
    9.35 KiB
Reply 1 of 14, by iraito
I went for a decent ps\2 keyboard and a ps\2 mouse (optical) i specifically searched for an MMX compatible mobo that offered ps\2 for the mouse.
If we talk reaaaaaally old pcs (amiga) i went for the original tank, which is surprisingly comfortable.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 2 of 14, by doublebuffer
iraito wrote on 2023-06-27, 19:46:
I really like my modern USB mice and keyboards, so comfortable, would be nice to use them with my AT PC but I guess there are no USB to ISA cards, at least I didn't find anywhere.
Reply 6 of 14, by ubiq
As someone just getting into retro tech this year, I feel you - my first build was almost stymied because I needed a PS/2 keyboard to get into the BIOS to enable support for my USB keyboard! So really IMO it's worth it to scrounge up some actual PS/2 peripherals even if they're not what you intend to use for the finished thing.
If you're very particular about your KB/Mouse setup, might want to check out the USB4VC project that lets you plug any USB KB/Mouse into a Raspberry Pi and then converts it to PS/2 or Serial port data and your retro computer is none the wiser. I've certainly found it handy.
Reply 7 of 14, by b0by007
As a newbie too, I had this problems with keyboard and mouse after I got my first retro builds last year.
On the 486 I was stuck with serial mouse (with rubber ball, really crapy) and DIN to ps2 adapter (bought 4 different adapters from chinese market until I got 1 in good quality build).
On the Pentium I got a ps2 mouse header bracket but it had a different pin layout then my motherboard.
So after that I searched for retro pcs with ps2 keyboard and mouse ports.
Now I use an UNISYS 486 sg3500 and an IBM PC 330 pentium 166, all with build it ps2 keyboard and mouse ports.
Is a nice experience to use modern peripherals (I can still find new ps2 keyboards and mouse, and some usb keyboards come with ps2 to usb adapters).
So another aproach is to change the whole pc for hustle free peripherals.
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 9 of 14, by dionb
Isn't that just a regular AT DIN keyboard connector? The mouse is pretty obscure, but the keyboard looks utterly normal. AT DIN and PS/2 are identical in terms of protocol and voltages, a passive passthrough adapter is all you need. Second the idea of just using a serial mouse in this case.
And if you are worried about PS/2 or DIN keyboards - consider that mechanical keyboards were actually the norm in the 1980s and more common than today in the 1990s. Alps white and Cherry black boards are pretty ubiquitous. Alps white (or any other Alps switches for that matter) is by far the better (if noisier) option, but the switches will need cleaning or they feel irritatingly scratchy and that's a big chore. Cherry black are hardly spectacular (fairly stiff linear switches), but generally maintenance-free so at worst you just need to wash the keycaps.
There are a lot more exotic switch types out there, but IBM's buckling-spring-over-membrane (Model M) suffers from bad 2KRO and capacitive buckling spring (Model F) are hard to come by, expensive and usually have for our modern tastes obscure layouts; BTC foam&foil were mushy when new, now the foam has almost certainly degraded and needs replacing, and then there are Space Invader switches etc etc.
There's a huge rabbit hole to dive down, but chances are if you find a keyboard of same vintage as that system, it will actually be mechanical. In case of doubt, look up the potential keyboard here: https://deskthority.net/wiki/
Oh, and avoid Cherry MY switches at all costs. "Prodding a dead squid" is too kind a description of how they feel 😜
Reply 10 of 14, by megatron-uk
Plenty of solutions to use modern usb/PS2 dual protocol mice if you don't have a ps2 mouse port.
You can either get a serial to PS2 external adapter:
https://www.serdashop.com/PS2TOSERIAL
Or, you can get an all in one solution with a PS2 mouse port on an ISA card:
Another PS/2 Mouse ISA (ISA8) card adapter
Plenty of modern usb optical mice still work with passive usb to PS2 adapters. Most Microsoft and Logitech stuff does (though obviously check first!).
The good thing about standardising on both PS2 mice and keyboard is that PS2 KVM switches are dirt cheap.
https://www.target-earth.net
Reply 11 of 14, by rmay635703
Babasha wrote on 2023-06-27, 23:04:
Its a HP-HIL mouse port((( Rare and unusual thing. Just use the COM-port serial mouse.
Gotta wonder why the ps2 breakout for that wasn’t reverse engineered
It appears to be mostly ps2 compatible as is, I doubt the logic is even as complex as the XT to AT keyboard adapter
Reply 12 of 14, by doublebuffer
megatron-uk wrote on 2023-06-28, 17:51:
Man that's so helpful! I need to get a few of those adapters and try them out. I read from the internet they would not work with modern USB peripherals, good thing I asked here before paying 30 euros for a serial mouse (the only offer for such mouse I found locally).
Reply 13 of 14, by megatron-uk
If it's any help, I use a Logitech Trackman Marble (usb) on all of my old systems with PS2 mouse ports, via a passive usb to PS2 adapter.
Reply 14 of 14, by doublebuffer
megatron-uk wrote on 2023-06-29, 06:52:
Sounds promising, I've been thinking of getting a trackball anyway so getting one with PS2 support would be double its duty.
