Sonic Buster 8: A NEW 8-bit ISA sound card with OPL3
First post, by LABS
Updated 21-07-2025
IN STOCK
Please PM me or drop an e-mail to eugenetongue@gmail.com for more information.
new.gif Sonic Buster 8 review on YouTube by root42
Sonic Buster 8 review on Retronautics by appiah4
Sonic Buster 8 home page - online manual, firmware updates, pictures and more
Hello there!
I'm happy to present my new sound card - Sonic Buster 8 😀
General features:
  • The firmware is based on the reverse-engineered original Sound Blaster 2.0 firmware
  • Fully compatible with Sound Blaster 2.0 8-bit mono PCM and ADPCM digital audio playback
  • OPL3 FM chip instead of OPL2 for FM music playback
  • CD/Aux stereo input
  • PC-Speaker input
  • Super quiet (around -100dB RMS) analog audio path:
    The attachment SB8-RMS.jpg is no longer available
  • Firmware is upgradable from DOS
  • Doesn't require a 14.32MHz clock from the ISA bus
  • Doesn’t need a -5V power rail to operate
  • Tested with 6/8/12MHz ISA speeds
This card is a result of my minimalistic approach to making a perfect sound card for modern DOS gaming needs. It is fully DSP-compatible with Sound Blaster 2.0 while adding a lot of extras.
The firmware now is a reverse-engineered original Sound Blaster 2.0 firmware rewritten for the AVR MCU. So, basically it is the same Sound Blaster 2.0 firmware inside a more performant AVR MCU. This results in a better stability and maintains a 100% compatibility with the most widely supported and simple DOS sound card - a mono Sound Blaster.
For FM music there is an OPL3 instead of OPL2 for better stability on faster machines and extra FM channels where available. For very old games there is a PC-Speaker input with a low-pass filter which makes it to sound and bit more pleasant. For games with CD music there is a stereo CD/Aux input, which I also use for connecting an audio output from my Dreamblaster S2. To mix everything together I implemented a quality analog mixer and put 4 volume pots on the back panel of the card as individual volume controls. The mixer eliminates any background noise on its output and can be connected to an amplified sound system or directly to headphones.
As a result, I came up with a nice sounding ISA sound card for modern DOS gaming needs - it supports the widest range of DOS games - from very old pcspeaker-only titles to CD-enabled ones and it is very easy to setup and use.
Sonic Buster 8 became an advanced version of the Blasterboard in almost every aspect 😀
Thanks everyone for the suggestions and reports since the release of Blasterboard! A lot of things are now implemented in SB8!
Blasterboard: DIY SB2.0-compatible ISA sound card on ATmega MCU
Reply 1 of 114, by appiah4
This is my wet dream 🤣
Reply 4 of 114, by Tiido
Large stencil is good, I pretty much always order full size for the important things... the ones cut to small size are often bent out of shape so much that they're hard to get good pasting with 😒
Welcome to the world of meat based pick & placing 🤣 (beats cutting and bending pins and hand soldering bazillion through hole parts)
Reply 5 of 114, by LABS
Tiido wrote on 2023-06-30, 10:58:
Needs some practice though to grip it well for a good contact in the center 😀
Reply 9 of 114, by appiah4
LABS wrote on 2023-06-30, 10:31:
Finally the prototypes.. and ridiculously huge stencil
That is one big ass stencil 🤣
Reply 10 of 114, by Tiido
LABS wrote on 2023-06-30, 12:49:
Making a perimeter using same thickness PCBs is exactly what I am doing, I tape them down to the desk so they cannot move and then I tape the stencil on them once it is perfectly aligned and then I do the swipe, with another PCB that is just as wide as one side of the PCB being pasted. It helps when the entire swipe is done in one go with good pressure, then the pads end up getting pasted nicely and there's no spillover which normally happens when I have to do anothes wipe in some other part as the stencil often lifhs slighly. It isn't gonna be a problem until you get ot 0.5mm pitch parts though, in which case even small spills can make unwanted bridges but with 1.27mm this is not gonna be an issue ~
Reply 12 of 114, by LABS
Tiido wrote on 2023-06-30, 17:02:
I used a plastic card instead and applied the paste with rapid short swipes and the stencil was moving up and down a bit and as a result there were some unpleasant bridges and poorly filled pads which I had to correct by a needle 😕
Your tips are very useful, will try next time, thanks!
Reply 13 of 114, by SaxxonPike
Wow! This is really impressive looking. Very tidy, very simplified. Having a discrete mixer is just perfect- we can then make adjustments on the fly without needing to route the individual signals to a mixer or bouncing between app and setup program.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 14 of 114, by appiah4
LABS wrote on 2023-06-30, 18:17:
Quite marvelous I must admit 😁
Now to the hard part - testing and debugging 🤓
Such splendour..
Reply 15 of 114, by shevalier
LABS wrote on 2023-06-13, 21:30:
Hello,
let me introduce my humble attempt to design an even more compatible and simple sound card for DOS 😀
Wow, for the first time I see a correctly cut plane between analog and digital.
Can I whine like an old man?
- Why no via stitching?
https://resources.altium.com/ru/p/everything- … -stitching-vias
- I would recommend using combo pads.
You can solder anything on them, starting from MLСС
- I would ground the mounting bracket a little differently.
- L1 and 2 are best replaced with 1-2 ohm resistors.
Filtering is the same, but there are no uncontrolled resonances.
- V1 and 2 are better to use LM317 / 338 with a capacitor on the adj pin of 10+ uF.
With a voltage drop of 5+ volts across them, they are much better than lowdrop regulators at noise and ripple rejection.
PS. Very nice design.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 16 of 114, by LABS
Thanks for your input, shevalier! I'm actually quite happy with current design with -95dB RMS noise floor which is more than enough for sound sources of such fidelity to consider the audio output as "dead quiet". However at the early stage of designing Blasterboard I already tried almost everything you mentioned. The first prototype even had 2 stages of voltage regulation to extremely reduce the PSU noise 😎
The attachment bbproto_assembled.jpg is no longer available
But the real tests showed that there is no improvement compared with a single pair of 79/78L0x regs when used in such noisy environment. So I dropped that idea in favor of simpler design. What really introduced a horrible noise - was grounding the bracket because of the ground loop. Anyway the construction does not allow to ground the bracket now, as it is mounted using nylon mounts.
L1 and L2 should go away and I'll put wires here, again, in favor of simplicity - the filtering frequency is far far away from the audio spectrum and even from the TL074's bandwidth anyway, so it does not affect the noise and there are 22p caps on opamps for stability.
Interesting article on via stitches by the way 😀
Cheers, mate! 🤙
