New Turbo Display project - Triple McDigit
First post, by dreamblaster
Hi
I am working on a new project : Triple McDigit / Turbo Display
It is a CPU speed display for your 3.5" drive panel, that shows your Normal and Turbo speed, synced to your mainboard turbo status.
UPDATE 01.06.2025 :
- updated photos and description
- project completed now and available here : https://www.serdashop.com/TurboDisplay
The attachment turbodisplay_front4_wb.jpg is no longer available
The attachment turbodisplay_rear_wb.jpg is no longer available
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 1 of 28, by Pierre32
Nice!
Reply 2 of 28, by MMaximus
Great stuff!! 😀
Hard Disk Sounds
Reply 3 of 28, by dreamblaster
new version configurable with dip switches, under development.
Reply 4 of 28, by keropi
very nice , the way to emulate the old looks using modern cases is now open 😁
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 5 of 28, by dreamblaster
New prototypes coming soon
Reply 6 of 28, by matze79
after some Brainstorming with Dreamblaster, a Solution for the last problems where found and finally a few Iterations later, all works well.
Here the Display is installed inside my Intel 486DX50 Mhz.
The attachment mcdigit1.jpg is no longer available
The attachment mcdigit2.jpg is no longer available
The attachment tripledig1.jpg is no longer available
The attachment tripledig2.jpg is no longer available
The attachment tripledig3.jpg is no longer available
Thanks for the hopefully Final Version @dreamblaster
Reply 7 of 28, by dreamblaster
Preparing first available units
here is some more information :
front panel :
connections :
The attachment turbodisplay_connections.png is no longer available
dip configuration:
The attachment turbodisplay_dips.png is no longer available
dot configuration
The attachment turbodisplay_dotconfig.png is no longer available
Reply 8 of 28, by maxtherabbit
another win for BCD gang
Reply 9 of 28, by feipoa
Very nice! A few questions:
1) How did you land on the colour profile for the bezel?
2) Is the bezel 3D printed, or from a mold/cast?
3) Will there be LCD colour options? I see how Matze has orange and dreamblaster has yellow. I think green was another common colour.
4) Are there any plans to create a unit which will fit into the two standard sized openings on the case itself? I think there were some full 3-digit MHz displays which fit, but they are harder to come by in the wild. 2-digit + 1 was more common, but 3-digit more desirable.
Reply 10 of 28, by dreamblaster
feipoa wrote on 2025-06-01, 13:55:
for a previous project, mccake panel, a large amount of 3d print samples were done from different PLA, to search for the ideal 'computer beige'
the first choice from this selection ran out, so now using the 2nd choice, which is also good
it is hard to do it justice on a photo
3d printed, on a textured print bed for nice front effect
it is the same led display in both, amber color, just different effect in the photo
if you can come up with specs for this, if there is some standard, i'd give it a try
Reply 11 of 28, by dreamblaster
Will be making a 5.25"bay as well, this is coming soon
Reply 12 of 28, by maxtherabbit
My understanding is there were basically two different footprints for case mounted LED displays but I have no idea where you'd get the dimensions other than careful reverse engineering. You could save a lot of board space by deleting the button and latch at least
Reply 13 of 28, by feipoa
The two common MHz display sizes were:
25.0 mm x 19.05 mm and with a depth of 7 mm
e.g. DA56-11SYKWA
https://www.digikey.ca/en/products/detail/kin … 11SYKWA/4098503
20.2 mm x 16.0 mm and with a depth of 7 mm
e.g. DA04-11YWA
https://www.digikey.ca/en/products/detail/kin … 4-11YWA/3084353
The examples shown above are for the yellow colour and are common anode, which is most commonly found in retro cases. Those are 7-segment, 2 digit. For a reproduction, we'd ideally want 3 digit. I don't have any 3-digit's in person, but here's an example of one on a case:
The attachment 3_digit_MHz_display_on_mini_tower.png is no longer available
The attachment 3_digit_MHz_display_on_mini_tower_zoom4.jpg is no longer available
It is difficult to determine which of the above two standard sizes this MHz display is. I don't think it has the decimal, which is an acceptable compromise.
The closest 3-digit, 7-segments MHz display I could find on digikey is: https://www.digikey.ca/en/products/detail/sun … DK09A3/21801098
The specs indicate that it is 22.5 mm x 14 mm, which doesn't conform to either of the two standard sizes. The challenge here would be to find a source for a 3-digit display in both of the standard sizes.
EDIT: Using GIMP and using the width of a floppy bezel as 101 mm, the MHz display in that photo comes in at 18x13.5 mm, which cannot be correct. The image resolution of the photo is fairly poor, so it is most likely 20 mm x 16 mm.
Reply 14 of 28, by maxtherabbit
That is helpful but you would still have to measure the screw boss offsets for the PCB mounting holes
Reply 15 of 28, by feipoa
Were those mounting points standardised? I have had to fudge these in the past, so probably no common standard. Best approach here might be to not route traces around common hole locations and have the user drill the PCB. If anyone is serious about this, I can measure some common screw hole locations.
I think the primary struggle is finding the 3-digit MHz display in the standard form factor.
Reply 16 of 28, by maxtherabbit
feipoa wrote on 2025-06-04, 07:06:
I thought so, but honestly I don't know
Reply 17 of 28, by dreamblaster
1st prototypes of 5.25" panel :
- 'bright' edition
- 'concealed' edition
The attachment photo_2025-06-10_20-16-36.jpg is no longer available
The attachment photo_2025-06-10_20-16-32.jpg is no longer available
what do you like best ?
both options should exist ?
Reply 18 of 28, by Stesch
Nice work! i think the left one looks much better in my opinion and more similar to 'original' old ones. BTW I love the DIP switches, much better than fiddling around with a bazilion jumpers! 😁
crayon eater (but only the tasty ones)
Reply 19 of 28, by matze79
Great idea to make the Diffusor with 3D Printer 😀
