ATC-5200 + k6-2+
Reply 40 of 53, by Sphere478
Typical is
Base =2.0v
Jp1 + .1v
Jp2 + .2v
Jp3 + .4v
Jp4 + .8v
With the combo of jp1-4 you can make voltages.
This is the typical layout of many socket 7 voltage setups
Looking at your voltage manual it seems to follow this. I assume to get to 2.0v you removed all voltage jumpers?
Sphere's PCB projects.
Reply 41 of 53, by brunofbrsilva
with all off or with the second one on it made no difference in the multimeter, I even found it strange, now all the other keys when turned on changed the voltage.
Reply 42 of 53, by Sphere478
brunofbrsilva wrote on 2023-07-08, 21:55:
Maybe there is something wrong with position 2
Reply 43 of 53, by brunofbrsilva
I thought the same thing, maybe position 2 has a problem, because, as nothing changes in the on or off position, possibly it is defective.
One question, considering the age of the motherboard, do you think it would be interesting to do a recap?
Reply 44 of 53, by Sphere478
brunofbrsilva wrote on 2023-07-08, 22:17:
It isn’t a bad idea, I personally only recap boards that have problems though. As to not tempt fate. (And be lazy)
But it is true that probably all capacitors that old of the electrolytic variety have probably experienced degradation. Other types may have fared better
Reply 45 of 53, by Chkcpu
brunofbrsilva wrote on 2023-07-08, 21:38:
See if this is correct:
Oh, I guessed wrong about the position of the Vcore controller IC. This 74F240 is a buffer IC, probably for the ISA-bus. 😉
Looking at the motherboard picture on TheRetroWeb, I see a likely candidate at the other side of the CPU socket, near the edge of the board. It has a large S like logo on top.
Can you send a close-up picture of that IC? Thanks!
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 46 of 53, by brunofbrsilva
yes of course, follow the photo:
The attachment IMG_20230709_154125887.jpg is no longer available
Reply 47 of 53, by BitWrangler
That seems like it's gonna be a CMOS RAM to hold some settings. http://www.allparts.co.kr/pdffile/pdffile_001/735.PDF
Reply 48 of 53, by BitWrangler
Well, found some clear-ish pic on an aliexpress listing, but still can't see the regulator IC clear enough to be sure..
https://www.aliexpress.com/item/1005004038474240.html
currently suspecting the tiny little 8 pin thing underneath the bottom toroid coil, under the CPU socket.
Reply 49 of 53, by Nexxen
@bruno: can you post high resolution pictures of the board?
Users here are going continents away to find a decent pics 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 51 of 53, by Chkcpu
BitWrangler wrote on 2023-07-09, 22:14:
Thank you BitWrangler, I believe you found the Vcore regulator IC! 😀
Although the photo on AliExpress is from an ATC-5200 V2.0 board, which has a different lay-out than the v1.0 board of the OP, I know now that we have to look for a tiny 8-leg chip.
So enlarging the V1.0 photo from TheRetroWeb, I located the tiny regulator chip close to the SW2 Vcore dipswitches. A logical place indeed. 😉
The attachment atc-5200-front-voltage regulator.jpg is no longer available
@brunofbrsilva, can you make a picture of that area so we can read the partnumber of this small 8-leg chip? With this info I can make a definitive Vcore selection table for you and for TheRetroWeb.
Thanks, Jan
Reply 52 of 53, by brunofbrsilva
Good night everyone, sorry for the delay here is the photo:
The attachment 16897196315287856556357238702384.jpg is no longer available
Reply 53 of 53, by Chkcpu
brunofbrsilva wrote on 2023-07-18, 22:35:
Thanks for the clear picture, yes this is the Vcore regulator we were searching for! 😀
However it is not the fancy regulator we were expecting. This AIC1579 is a simple step-down controller with a single feedback input. It uses an external resistor network on the motherboard to make other voltages than the base 2.0V.
This is the typical schematic from the datasheet:
The attachment AIC1579 schematic.png is no longer available
So the values of the resistors connected to the 4 VID switches determine the selectable output voltage. With the resistor values from the schematic, you will get these possible output voltages:
The attachment Output Voltages.png is no longer available
But we now know that the base voltage of this regulator is 2.0V and that you should set all four SW2 dipswitches to OFF to get this voltage for your K6-2+ CPU! 😉
Here is the complete AIC1579 datasheet:
The attachment AIC1579.pdf is no longer available
Karbist wrote on 2023-07-10, 11:01:
https://datasheetspdf.com/pdf/136498/AnalogIn … ation/AIC1579/1
I got 2.0v on vcore with all 4 dip switches set to off.
@Karbist, thanks for the datasheet. You also found this regulator chip on your board.
Great that you could confirm the 2.0V Vcore with all 4 dipswitches off. 😀
Jan
