brunofbrsilva wrote on 2023-07-18, 22:35:
Good night everyone, sorry for the delay here is the photo:
Thanks for the clear picture, yes this is the Vcore regulator we were searching for! 😀
However it is not the fancy regulator we were expecting. This AIC1579 is a simple step-down controller with a single feedback input. It uses an external resistor network on the motherboard to make other voltages than the base 2.0V.
This is the typical schematic from the datasheet:
The attachment AIC1579 schematic.png is no longer available
So the values of the resistors connected to the 4 VID switches determine the selectable output voltage. With the resistor values from the schematic, you will get these possible output voltages:
The attachment Output Voltages.png is no longer available
But we now know that the base voltage of this regulator is 2.0V and that you should set all four SW2 dipswitches to OFF to get this voltage for your K6-2+ CPU! 😉
Here is the complete AIC1579 datasheet:
The attachment AIC1579.pdf is no longer available
Karbist wrote on 2023-07-10, 11:01:
@Karbist, thanks for the datasheet. You also found this regulator chip on your board.
Great that you could confirm the 2.0V Vcore with all 4 dipswitches off. 😀
Jan
