retep_110 wrote on 2023-07-10, 10:09:
As of know I feel the Pentium MMX 166 MHZ is to right choice but I migth ge tempted to play some more power in the future.
You could future proof by getting a 233MMX, and jumper it to 166MHz if that's the speed you want now 😀
Bancho wrote on 2023-07-10, 15:55:
kaputnik wrote on 2023-07-10, 09:40:
Done something similar with my P233MMX/GA-586HX system, using separate toggle switches though. Also did a dual BIOS/RTC setup, to be able to switch between the original Award BIOS and MR BIOS 😀
Thats really cool! Can you elaborate on the AWARD/MR.BIOS mod? Sound interesting!
Well, basically I just replaced the original 1Mbit EEPROM with a 2Mbit one, and installed an interposer made from a DIP32 socket between BIOS EEPROM and mobo. The interposer lets me control the highest addressing pin (A17) manually with a switch, effectively letting me select the first or second half of the EEPROM to read from.
The BIOS saves the "CMOS settings" to memory in the RTC. Without a second one, I'd have to reconfigure the BIOS each time I switch between them. It's just two DS12885 RTC:s connected in parallel, sharing a battery. They're selected by pulling /CE low on either chip with the switch. The same approach could be used for the BIOS EEPROM(s) aswell, if you rather want two 1Mbit than one 2Mbit chip.
The connector for the RTC module socket on the mobo is made from another DIP socket, some hot glue, and a 3D printed shell.
Electrically it looks like this. Good thing I took the time to draw up a diagram:
And a couple of photos:
Couldn't find any pics of the interposer, but it's not much to see anyways. Just a 32 pin DIP socket and a resistor 😀
