First post, by HanSolo
 - Member
I often get old PCs from various sources (family, friends, friend's friends) but even with interesting stuff comes along a lot of stuff that I don't need. I try to keep as much as I can because 'you never know'. So meanwhile I have a boxes full of IDE HD-, CD/DVD-, floppy-drives, ATX PSUs, several old grey ATX-cases, and LCD-monitors.
The cases are easy because the eat up the most space so they will be dumped when I need that (the hard part is deciding which cases shall go). But for all the rest, I justify it by saying that one box more or less doesn't matter.
Do you guys have similar problems? I mean it's not really a problem to have 3 boxes full of IDE harddrives (unless they need to be moved around...) but it's also pretty pointless, isn't it? And selling such stuff isn't worth the time since those are no valuable items.
