First post, by Ryder252
- Newbie
Hello and good afternoon!
I'd like to get Paul Rickards's WiFi 232 Hayes-compatible modem to provide connectivity to the web with TCP, alongside bbs's in a terminal emulator. Problem is, every TCPCOM-like program I've found is either incompatible with 98 or doesn't allow modem connectivity without entering a phone number(the 232 doesn't actually use one). Is there a way to bridge the com port to a TCP stack without using an external system?
