First post, by Nexxen
I tried using wine to detect the USB device but after a couple of guides I can't make it detect it.
USB isn't available.
Does anyone have a clue on how to make it work. Currently I have to use a laptop with Windows on it and it slows things down.
Thanks for any input.
Guide I tried, but .dll can't be downloaded:
Using the XGecu TL866II Plus Under Linux with Wine
04 Jul 2018
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 6, by majinga
Have you set the udev rules correctly?
To use the original sofware with wine you can use the wrapper from radioman: https://github.com/radiomanV
Reply 3 of 6, by Nexxen
majinga wrote on 2022-11-07, 17:25:
I tried following radiomanv instructions but it doesn't work anyway, there are errors.
I use linux but I'm not an expert.
https://github.com/radiomanV/TL866/tree/master/wine
sudo cp ./udev/* /etc/udev/rules.d/ && sudo udevadm trigger
returns an error for unknown directory
Reply 4 of 6, by majinga
Can you return the specific error?
Are you in the correct directory while you launch the command?
Reply 5 of 6, by Nexxen
majinga wrote on 2022-11-11, 17:47:
I'll do it again following the instructions and I'll report every step.
Reply 6 of 6, by Nexxen
I followed every step on 2 new machines and it worked.
My guess is some corrupted files not working. Go figure...
I have to admit I upgraded from version 18 to 21... maybe it was time for a fresh install.
I can call it
- The End -
