Reply 80 of 265, by Irinikus
 - Oldbie
I've had the 4.5mm stainless steel plate cut to size, drilled and skimmed down to 4mm and I've now ordered the required tapping kit to tap the holes with the correct thread: (This will give the required space for the CEK Springs to sit between it and the motherboard.)
This is how the plate looks with the CPU Coolers positioned on it:
So I'm getting there slowly!
