ATi Mach32 VLB VGA card, quick test
Reply 40 of 64, by douglar
I'll dump the bios when I get a chance and poke around with my clumsy binary ready skills to see if I can spot anything.
Reply 41 of 64, by douglar
douglar wrote on 2020-11-05, 21:49:
OK, I feel more stupid than usual. Perhaps I truly have begun to enter my dotage.
Here's the deal. The other chip is not a rom at all.
I had it in my reader and got out my magnifier to read the small print. Just about rammed my glasses through my head with the resulting face palm.
The other chip is the ATI68830 RAMDAC.
The attachment Photo Nov 06, 2 51 54 PM.jpg is no longer available
So the reason for the double image is pretty freakin clear in hindsight. Double image because I had two ramdacs.
All I had to do was pull the ATI68830 and it was all good. Both the TLC34075 and the TLC34076 were compatible with the Mach32 card all along.
If anyone wants a spare TLC34075 for their mach32 card, let me know and I'll be happy to mail it away so there's fewer reminders of this incident in my life =)
Here's a link to the rom that I dumped--
https://www.dropbox.com/s/fv6m6uwondp5bd5/VLB … 0.1993.BIN?dl=0
Reason: Attached ROM to post (dropbox link will go bad within a year or two)
Reply 42 of 64, by Kar
I read this somewhere and was trying to find the link to where I'd seen it, but yeah the second dip socket was either labelled even BIOS or the original RAMDAC.
Glad you got it sorted!
That said, these kinds of debugging hijinks and occasionally eureka moments are why we do this right!?
Reply 43 of 64, by douglar
I tested a VLB Mach32 EXM195a 2MB VRAM:
The attachment EXM195a.jpg is no longer available
against a VLB Mach32 EXM229 2MB DRAM:
The attachment EXM229.jpg is no longer available
on a 486dx2-66 equipped Shuttle HOT 419 v1.0 mobo utilizing a Opti 82C894 chipset & 512kb cache.
I compared landmark scores--
  • Mach32 EXM195a VRAM -- 7,740 char/ms - 7740 is the slowest VLB score that I've seen
  • Mach32 EXM229 DRAM -- 10,922 char/ms - 40% faster
I also did the high quality doom benchmark on both cards.
  • Mach32 EXM195a VRAM -- 2,869 realtics -- One of the best VLB scores
  • Mach32 EXM229 DRAM -- 2,693 realtics -- The best VLB score I have seen on this system
Not sure why the landmark scores are so bad but the doom scores are so good.
Would something like UNIVBE 6.7 improve landmark scores?
Reply 44 of 64, by Anonymous Coward
Aren't the landmark graphics scores just based on text modes?
Since when was landmark a reliable measure of anything anyway?
Reply 45 of 64, by Veeb0rg
douglar wrote on 2020-11-06, 20:06:
OK, I feel more stupid than usual. Perhaps I truly have begun to enter my dotage. […]
Thanks for the ramdac, can't wait for the extra ram to get here so I can upgrade my card!
Reply 46 of 64, by Asmodeusbell
I have tried a Ti TLC34076-170FN, it has seemed to work as the system posted and display with the Ti ramdac. Need to test further in benchmarks and games.
Remove JU6 jumper and U32 ATi68830 (if present) to use the Ti TLC3407x chips in U30 PLCC socket.
Both the Ti TLC34076 and TLC34075 are pin compatible and feature set compatible with the ATI68875.
Someone asked about the Ti TLC34058, this chip is NOT compatible in any way. (Ask me how I know.)
I have a Mach32 VLB. Mach32 2200688003 (9245)
FCC ID: EXM195
ATI PN: 1090019530
ROM: VLB Mach 32(A) 113-19500-100 (C) 1992.
Originally had 1MB and the 68830P-80 Ramdac in U32.
Upgraded to 2MB and the TI TLC34076-170FN.
I have post tested with TC524258BZ-80 (early 95) and MT42C4256Z-8 (mid 92) ZIP VDRAM chips.
They are Video Dram, Fast Page, 256Kx4bit, 28pin ZIP.
At the time of this post I have 12 of the TI TLC34076-170FN chips.
Reply 47 of 64, by dj_pirtu
I have ATI Mach32 in my ICL D4/66XGi, on motherboard and VLB connected. It's sick fast BUT not that compatible with demoscene productions.
Reply 48 of 64, by Asmodeusbell
I still have the Ramdacs available. Not able respond to DM at this time.
Reply 49 of 64, by CoffeeOne
Asmodeusbell wrote on 2023-08-21, 16:44:
Hello,
I have a similar card as posted above with VRAM:
2MB, no sockets all 2MB soldered.
RAMDAC TLC34076-135FN.
But soldered, no socket.
Would the 170MHz RAMDAC give some additional modes?
Anyway I am not going to desolder the existing RAMDAC, so upgrading is not an option.
Reply 50 of 64, by douglar
CoffeeOne wrote on 2023-08-22, 10:09:
Can you post a picture of your board? If there's a socket for a new ramdac, there's probably a way to disable the one soldiered on your board.
If you have 2MB of RAM on your card, the 170Mhz Ramdac will allow for >=60Hz refresh rates at 1280x1024x8 or 1024x768x16.
If you only have 1MB of RAM on your card, you can't do those modes, so there's less benefit to the faster RAM DAC.
Reply 51 of 64, by CoffeeOne
douglar wrote on 2023-08-22, 17:07:
Can you post a picture of your board? If there's a socket for a new ramdac, there's probably a way to disable the one soldiered […]
Picture!
The attachment PXL_20230822_180211375.jpg is no longer available
Reply 52 of 64, by douglar
CoffeeOne wrote on 2023-08-22, 18:06:
Picture!
That's a nice clean looking card. I realize now that I jumped back into a conversation and had missed a post.
I thought you were talking about upgrading from a slower 85MHz ramdac, which would have been in a DIP28 socket in the empty space right below your 135MHz ramdac.
But you were not talking about that. You have a 2MB card with the 135MHz ramdac, and you can do the good refresh rates at 1280x1024x8 and 1024x768x16.
You are talking about adding a over spec'd 170MHz ramdac. Interesting idea. Not sure how it would help though.
If you were having image quality problems, maybe, but all the output I've seen with the 135MHz has been well above average.
If you wanted to try to reach any modes that were not available on the 135MHz ramdac, I imagine you would need to make a custom BIOS or Driver. The current software probably won't know about the higher speeds.
Reply 53 of 64, by Asmodeusbell
The TI TLC34076-170FN doesn't add anything over the 135 speced part. It was only ones I could find, and was only in bulk. To replace the 68830P-80 Ramdac.
If you already have the TI TLC34076-135, no real point of getting the 170 ramdac. If you have a card with the ATI 68830P ramdac and have a PLCC socket for the Ti ramdac, then yes, either the TLC34076-135 or 170 is an upgrade.
Reply 54 of 64, by SoryuDragon
Reading this post... I have questions.
I have the 113-19509-100 card. Only has 1MB. I'd like to upgrade the VRAM. But no idea what to order.
Does anyone have part number for the correct VRAM to find on eBay or other?
Thnx
Reply 55 of 64, by Beerfloat
SoryuDragon wrote on 2026-02-03, 22:07:
Reading this post... I have questions. […]
Thnx
113-19509-100 is EXM195A (check white text silkscreened on the card), which uses VRAM.
Usually in the shape of 28-pin ZIP memory like the Toshiba TC524258BZ-80. Look at your empty memory slots to confirm they are the zig zag inline package type.
Reply 56 of 64, by douglar
Beerfloat wrote on 2026-02-03, 23:29:
Thnx
Upgrading the ram is a great idea on this card. It increases the memory from 32bit to 64 bit.
And you will want to make sure you have the faster ramdac too.
You don't want the DIP ramdac, you want the PLCC ramdac. The ATI68875, TLC34075 and the TLC34076 are the most common options and they all work.
The attachment Screenshot 2026-02-04 091936.png is no longer available
Reply 57 of 64, by SoryuDragon
douglar wrote on 2026-02-04, 14:25:
Upgrading the ram is a great idea on this card. It increases the memory from 32bit to 64 bit. […]
Thnx
I found on eBay and ordered the TLC34076-170FN... Let me guess, wrong RAMDAC?
Reply 58 of 64, by SoryuDragon
Thnx
Silk screened is... FCC ID: EXM195A P/N: 109-19500-50
Zigzag inline, Yes.
If I search on eBay for the Toshiba TC524258BZ-80, that is what I should buy? I would need 8 of them?
Reply 59 of 64, by douglar
SoryuDragon wrote on 2026-02-07, 12:42:
Should be fine. Same instruction set. The 170 mhz version should have no problems running at 135mhz.
Once you insert the new chip, just make sure you remove the old dip ramdac or you get a wierd double picture. Dont ask me how I know …
