First post, by copper
I didn't see this exact board discussed anywhere online.
This is a Headland (distributed by Video 7, I guess?) VGA card with HT209 chipset. The PCB is labeled 650-0221-03 and the FCC ID is D2AVRAMII209B so I guess it's an early VRAM II variant. It looks very similar to the card in this post Re: Bought these (retro) hardware today but has some differences, like an HT209/A3A0014 instead of an HT209/D, the jumper header in the center instead of by the slot connector, and no 512KB expansion board, although the headers are there. I got it at the MIT Swapfest for $5 from a guy who had at least 20 of them, along with a similar number of Mwave cards. All appeared to be OEM new old stock.
I tried the card in a 386 (16 bit slot) and it worked ok when I set DIP 7 to open. I tried it in my XT as well (8 bit slot) and it worked fine with all DIP switches closed. I was surprised to see the XT boot in VGA. I didn't find a configuration reference or manual online that seemed to match. It came in the anti-static bag with all switches closed.
Anyway, if you need an 8 bit VGA card, this card seems to work. Maybe I should go back and see if the seller has the RAM expansion boards.
Apparently there is a very similar card (VRAM II Ergo) that can do DB9 TTL output with an adapter: https://forum.vcfed.org/index.php?threads/uni … 75/#post-393332. I would use that if it really works; I was looking for an ATI VGA Wonder for that same reason.
Reply 1 of 7, by copper
I found a picture of a box and "Ergo" seems to refer to supporting a 72hz refresh rate. Presumably the rest of the features are identical between the VRAM II and the Ergo, except for bugfixes.
Also, somebody bought the manual on Ebay a few months ago...whoever you are, please scan and upload it.
Reply 2 of 7, by pshipkov
Most VGA cards will work fine if inserted into 8-bit isa slots. Including on XT clones - either 8088 or 8086.
The only cards that may cause problems are very late models based on Cirrus Logic GD-5434.
retro bits and bytes | DOS media library
Reply 3 of 7, by clb
Your HT209 card looks newer and more sophisticated than my Headland HT208 card at: Can your VGA card provide a hardware source for random numbers? .
A Headland technical manual can be found at http://www.bitsavers.org/components/video7/70 … anual_Jun88.pdf , but I don't know which Headland cards/chips this "Headland V7 VGA" exactly relates to.
In any case, page 243 of the PDF documents the DIP switches on the board:
The attachment headland_dip_switches.png is no longer available
Next page mentions jumper settings, although your board does not seem to have any:
The attachment headland_jumpers.png is no longer available
The fact that a board has DIPs/jumpers for enabling/disabling 16-bit operation is a good sign that it will support 8-bit ISA slots.
Also, Headland is probably the only manufacturer ever to have a dedicated hardware switch for disabling all manufacturer specific VGA extensions (DIP8 - Pure mode). Even if that is not particularly important, seeing that option makes me think high of the engineers, they had a careful attitude towards hardware development. (the data sheet overall shines of quality compared to datasheets from other manufacturers)
In Commander Keen 5 1.0 I did run into a timing related hardware quirk on this card that hidden sprites would appear out of random. I don't know why this card specifically would exhibit such glitches (I tested many other VGA cards in the same PC, Headland was only card to give those glitches), although it is well known the vsync implementation in Keen 5 1.0 struggles a bit, and the code was revised in several later versions.
The attachment headland_video7_keen_glitches.png is no longer available
(don't remember if I tested other Keen versions or the Fix Jerky Motion fix to check if that might have fixed it)
With that unique card, you get to play the most awesome and the only game ever developed specifically for Headland cards in mind: RNG Space Adventure 😁
Reply 4 of 7, by copper
pshipkov wrote on 2023-09-05, 04:30:
That's good to know. Is it also normal for them to support DB9 TTL output with an adapter? I found an adapter on Amazon that looks right; I will give it a try.
clb wrote on 2023-09-05, 10:57:
There is a 3 pin jumper header marked E1 to the right of the HT209 chip. Hard to see in the picture. It came jumped with 2-3 jumped. This header is not present on pictures of revised VRAM IIs. It probably matches one of the four jumper settings you found; maybe it's memory disable because I don't have the expansion board.
I found a page of "Video Seven V-RAM Information" on minuszerodegrees, it seems close but I still don't think it's the VRAM II. But the DIP options appear to match your manual, so it's probably the same for all Headland ISA VGA cards. I wonder if V7VGA.COM is really necessary for CGA and where to get it.
This page mentions that the 8.05 BIOS I have is buggy: https://www.betaarchive.com/wiki/index.php?ti … _Archive/102138 Maybe that's why this stock of cards (along with the MWaves) never made it into any PS/2s. I wonder if it would be possible to upgrade the BIOS.
With that unique card, you get to play the most awesome and the only game every developed specifically for Headland cards in mind: RNG Space Adventure 😁
Haha, what is that? CRT Terminator project looks cool. Do you need a Headland HT209? I can probably go get more of them.
Reply 5 of 7, by clb
I was also looking for V7VGA.COM utility at some point. There was a download link at https://dosdays.co.uk/topics/Manufacturers/vi … o7_vga1024i.php to utilites, but the link is dead. Some other files are available there though.
Thanks for looking out - though I am located in Finland, so shipping and customs would probably already make it not worth the hassle. If you have a moment to run SNOOP on it to check if it does properly detect the HT209 variant, that would be interesting. SNOOP.EXE: (S)VGA adapter info tool and CRT Terminator config utility
Reply 6 of 7, by copper
clb wrote on 2023-09-05, 19:58:
That link still works for me; V7VGA.COM is in the 1024i Util 1 disk, attached here. There is also a "VRAM-II ERGO Utilities Disk". It includes a nested zip that has V7VGA.EXE, which is labeled in the README as "Screen save and emulation utility," same as the .COM version is.
Reply 7 of 7, by SA1988
Not to bump this, but I'm a bit interested into this video card as well, the VRAM II/HT209D I mean, in ISA form, so, is it possible to upload a dump of it here please?
