Reply 50460 of 58935, by keropi
Ensign Nemo wrote on 2023-09-20, 01:59:
Thanks. I still need to learn to solder. Hopefully whatever the problem ends up being is an easy fix.
+1 to Shponglefan's estimate
it is 99.5% solder cracks on the connectors
it's an easy fix that does not require a huge solder experience, basically with the board removed you flip it over , introduce the solder iron to the big solder joints of the connectors, heat it up and maybe add a small amount of fresh solder... and that's it 😀
Reply 50461 of 58935, by Ensign Nemo
keropi wrote on 2023-09-20, 04:50:
+1 to Shponglefan's estimate it is 99.5% solder cracks on the connectors it's an easy fix that does not require a huge solder e […]
I'm glad to hear that. I'll look into this. Thanks for the advice.
Reply 50462 of 58935, by H3nrik V!
+1 to this, as well as the very probable diagnosis ..
Reply 50463 of 58935, by pentiumspeed
Back in the day, I was happy with AMD 486DX 40 overclocked to 50 on an VLB board for about 2 years, and next year I got Pentium 100 machine. This why was I skipped DX2 and DX4 era, eventually got PII 350 machine.
Today, I received 486DX4 100 CPU. I already gotten a metal clip on heatsink for it. Metal clip on heatsinks is incredibly hard to find but this comes from experience with plastic clips in general f0r any processors being a issue.
Even intel back in the day when P4 was so new, intel had trouble with white lever locks breaking if you put or take off. Made awful sound of locking on or off, grind/crunch.
Cheers,
Great Northern aka Canada.
Reply 50464 of 58935, by Socket3
Got lucky at the flea market this past couple of months so I tought I'd share some of my findings.
386 motherboard with L2 cache and an AMD 386-DX40 sitting on some kind of interposer - untested, but looks like it's all there, and I can't see any corrosion. No barrel battery witch is a plus, but on the other hand it's using a Dallas RTC witch I am not fond of.
The attachment IMG_20230921_123855337.jpg is no longer available
These 3 are all VIA 82C694T Pentium III Tualatin motherboards with an ISA slot. I've been hunting boards like these for hybrid DOS/Win9x builds. All of them tested fine, but they all had bad caps. The Epox and MSI got fresh 1500uf 6.3v caps. Both had 3-4 bloated capacitors, all 1500uf, but I replaced all 1500uf caps on these boards just to be safe. The Trancend on the other hand has loads of bloted caps, over 6 1000uf and 3 or 4 1500uf caps. It posts, but I won't do any extensive testing on her until I can order new capacitors. The MSI has pretty decent overclocking options, I was able to run one of my 1200MHz Celeron Tualatin chips at 1600MHz (12x133 / 1.6v) stable. The Epox was a really nice surprise since it FULLY supports the VIA C3 Nemiah. I even got new bios options when running the C3, like "C3 Multiplier Selection". The MSI and Trancend motherboards did not come with a northbridge heatsink, witch is odd since the 694T gets pretty hot when running a Pentium 3-S (measured 67C with an IR thermometer) - so I added a heatsink on the MSI and plan to add one to the Trancend after recapping.
The attachment IMG_20230921_123851393.jpg is no longer available
The attachment IMG_20230921_123846310.jpg is no longer available
The attachment IMG_20230921_123429514.jpg is no longer available
A couple of creative sound cards (SB16 and an AWE64 value), a couple of ESS sound cards and a Radeon 8500 AIW.
The attachment IMG_20230921_124346822.jpg is no longer available
Reply 50465 of 58935, by PcBytes
At this point it seems luck avoids me, the oldest board I could score were a MSI K8T Neo + a artefacting NX6600GT.
The oldest chip I could get was a Deschutes 266 w/ AVID fan and thermal sensor though, so that's a neat thing to find.
Reply 50466 of 58935, by oh2ftu
Socket3 wrote on 2023-09-21, 10:17:
That MSI board will cook that audio chip (VT1612 IIRC). The schematic is available at elektrotanya.com.
The supply voltage is 5V, when that audio chip can take 3,3V. I modded my board. Found 3,3V somewhere near the AGP slot and removed one inductor from the 5V feed to cut it.
Reply 50467 of 58935, by Socket3
PcBytes wrote on 2023-09-21, 11:19:
Lady luck can be a fickle mistress... I got this haul recently, along with 3 more or less complete PCs (one IBM Netvista P4 and two beige box PCs with desktop form factor standard ATX cases) and a laptop (this happened in the past couple of months) but before that - dry. Nothing of interest. Only newer hardware I was not particularly interested in.
This pic didn't fit in the other post - 5 picture limit and all. Finally got a hold of a geforce 256 DDR. The tiny blue video card is a Gigabyte Riva TNT2 PRO. An odd little board, it has a jumper that allows the user to choose it the card runs at standard mode or OC mode. The hercules card is a Kyro II. They make for fairly decent geforce 2 pro replacements.
The attachment IMG_20230921_124519622.jpg is no longer available
oh2ftu wrote on 2023-09-21, 11:31:
Thanks for letting me know. I don't plan on ever using on board sound - that's what the ISA slot is for. Might as well remove the chip complexly or lift the leg that provides power to it off the board.
Reply 50468 of 58935, by PcBytes
At least the ones where I live in get more scarce by each Sunday. I swear, I barely see any boards at all. Just a whole sea of laptops ranging between Core 2 Duo and 2nd or 3rd gen Cores.
Reply 50469 of 58935, by Kahenraz
Shponglefan wrote on 2023-09-20, 01:50:
Ensign Nemo wrote on 2023-09-20, 00:26:
Just picked up an SC-55 today! Unfortunately, I'm only getting sound out of one of the RCA outputs. I'll keep it, as I can use the headphone jack, but it would be nice to be able to use the RCA jacks working too. I tried a factory reset and checked the panning. Neither of these helped, so I suspect that the jack is faulty.
Could be a cracked solder joint. I find that tends to happen on things like power or audio connectors with a lot of use.
It's not uncommon to find cracked solder joints in these old synthesizers. There is a lot of stress being put onto these ports.
See there for photos of one of my SC-55 refurbishments.
Roland SC-55 Refurbishment
Reply 50470 of 58935, by Ensign Nemo
Kahenraz wrote on 2023-09-21, 16:41:
It's not uncommon to find cracked solder joints in these old synthesizers. There is a lot of stress being put onto these ports. […]
Thanks! I really appreciate all of the helpful suggestions and comments.
Reply 50471 of 58935, by H3nrik V!
Wonder if that interposer is just for the socket or it might have some coprocessor on the underside, or was that only something seen on Cyrix?
Reply 50472 of 58935, by Ensign Nemo
Bought my first Mac today, an eMac. I hate the mouse already. Lol.
The attachment emac_g4_booting.jpg is no longer available
I don't know much about Macs, but I had been thinking of getting one for the science and educational software. Seems like they have a lot of stuff that isn't available on PC. This one has a PPC under the hood and is basically a hefty CRT, so it's retro enough for me.
The attachment emac_g4.jpg is no longer available
Reply 50473 of 58935, by debs3759
H3nrik V! wrote on 2023-09-21, 21:32:
No, it's just the CPU. Fairly common, I've seen lots sold. May even have a couple somewhere.
Reply 50474 of 58935, by Nexxen
Some serial and PS2 mice.
The green ones are funny stuff. I looked up for the brand and it turns up it's a freebie for MDs.
They actually are of good quality and inside it's solid, not those low weight budget ones.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 50475 of 58935, by DerBaum
Nexxen wrote on 2023-09-22, 21:10:
...mice...
Oh a Microsoft Mouse... In a similar shade of yellow as mine (was) 😁 ...
They turn out great when sun brighted for some days.
They are a must have.
Everybody knows that the floppy symbol to save is an actual floppy...
But only true Nerds know that this mouse is the Icon for the Mouse settings in windows 3.0 (and 3.1) (and on the icon for the control panel itself in 3.1) 😁
The attachment tumblr_fb205f6f7b8e551502be6e3abf84c443_a9b07124_540.png is no longer available
The attachment win31.png is no longer available
FCKGW-RHQQ2
Reply 50476 of 58935, by Nexxen
DerBaum wrote on 2023-09-22, 21:25:
I have to clean wheels and retrobrite. How did you proceed?
I didn't, thanks for this "nerding" boost!
Good old 3.1 😀
Reply 50477 of 58935, by DerBaum
Nexxen wrote on 2023-09-22, 21:31:
I just put the stuff in the sun like here : What retro activity did you get up to today?
and after some days i clean them and they look like this : Re: What retro activity did you get up to today?
No chemicals, just sun. 😀
FCKGW-RHQQ2
Reply 50478 of 58935, by Nexxen
DerBaum wrote on 2023-09-22, 21:39:
I just put the stuff in the sun like here : What retro activity did you get up to today? […]
Will try, hassle free.
Thanks! and thanks for the other one 😉
Reply 50479 of 58935, by Grzyb
For me, a 2-button mouse is must NOT have.
Most amusing is the fact that the Minesweeper game shipped with Windows... pretty much requires a 3-button mouse 🤣
Well, it's possible to play it with just 2 buttons, but very inconvenient.
