Vanessaira wrote on 2023-09-26, 21:21:
After prepping the PLCCs, where would it go on the AWE32 for example?
I presume the DSP chip is on different location on the PCB depending on  the exact AWE32 model and thus I cannot speak for all models, but on mine CT2760 it's the following chip - CT1741 - it's also the only PLCC-44 packaged chip on the PCB and thus easy to locate just by that:
The attachment ct2760_dsp_location.jpg is no longer available
as you can see even the exact version "V4.12" is written on the chip. So, in my case will be double upgrade - not only to V4.13, but to bug-fixed V4.13 (big thanks to @Maelgrum). So, the steps are:
1. de-solder the original chip
2. install PLCC-44 socket
3. use external programmer to program new replacement chip with what is posted here
4. install that new chip from step 3.
And I have one questions myself for step 3 : do only AT89S52 and AT89C52 tested and confirmed as working for a replacement chip?
