The Soundblaster DSP project
Reply 560 of 1053, by georgel
Maelgrum wrote on 2023-10-04, 14:37:
0xC0 at command loop 0xC2 at entering midi loop 0xC4 in midi byte write routine […]
georgel wrote on 2023-10-04, 14:29:
What do you assume SP to be at MIDI byte write routine in 4.16?
Sorry , I meant the word pointed by SP=C4 at MIDI byte write. The above is the same in every version.
Reply 561 of 1053, by Gmlb256
Gmlb256 wrote on 2023-10-04, 14:17:
I will try again to see if there is any difference with the recent versions.
Got some good results on my side! 😁
I have to disable NMI on each test though.
    CT4520_TEST5.ZIP
    19.33 KiB
    25 downloads
Reply 562 of 1053, by mattw
Maelgrum wrote on 2023-10-04, 14:39:
Thats strange, what last version gives nonsense, but old gives something more sane. Will look into this.
so, going log by log from my posts here, because I posted all logs from my tests, only the very fist version gave "passed" on 1183:
Re: The Soundblaster DSP project
all subsequent versions - failed, if I did not miss to review some of logs from my posts.
Reply 563 of 1053, by DerBaum
DerBaum wrote on 2023-10-04, 04:13:
...but in duke nukem it always has a dma error. maybe its broken too.
To not let this stand there on its own.
Result:
Of course it was an user error and not the cards fault.
The Vibra16VX uses the same DMA channel (in my case 1) for 8 and 16 bit.
I foolishly assumed it uses 1/5 like all other cards.
Duke nukem (the game i test my cards with) doesnt allow me to set the same DMA for 8 and 16 bits, so it cant work.
After setting duke to use 8bit sound fx it started working.
FCKGW-RHQQ2
Reply 564 of 1053, by Maelgrum
Gmlb256 wrote on 2023-10-04, 14:41:
Looks very good !
Reply 566 of 1053, by Maelgrum
On this 2 matches - prepared 2 versions:
Reply 567 of 1053, by Gmlb256
mattw wrote on 2023-10-04, 14:56:
Maelgrum wrote on 2023-10-04, 14:52:
Looks very good !
is it the "ST4" log, because that ST5 log is the same as the one I posted about 1 hour ago here:
The ST5 log file was just to make sure, I didn't copy yours. The timestamps are different with the correct year on mine.
Reply 568 of 1053, by Maelgrum
Gmlb256 wrote on 2023-10-04, 15:00:
Looks very good !
Match on ST4 must be 3 bytes before match on ST5. Then it looks very promising. And exactly this picture i see i logs - 3 byte difference is present.
Reply 569 of 1053, by georgel
Congratulations, and thanks for using E3.
Now its time to try it on CT39xx for those with soldered sockets.
    986E5CB9.rar
    3.53 KiB
    30 downloads
Reply 570 of 1053, by mattw
WINNER - DUMP SUCCESS
P.S. both version work and produce the exact same dump.
Maelgrum wrote on 2023-10-04, 15:02:
very good luck of @Gmlb256 with that ST4 log, I continue to get all "failed" with ST4 on my CT4170 V4.16 (even now I dumped it succesfully). So, definitely something more affects the ST4 success.
    dp1.zip
    18.12 KiB
    27 downloads
Reply 575 of 1053, by Gmlb256
Maelgrum wrote on 2023-10-04, 14:56:
Uploaded the successful dumps from both recent versions of SB16DUMP.
Maelgrum wrote on 2023-10-04, 15:12:
I don't have words to describe how happy I am !
Kudos to all !
Thanks! 😁
    CT4520_DUMP.ZIP
    9.1 KiB
    32 downloads
Reply 577 of 1053, by maxtherabbit
S95Sedan wrote on 2023-10-04, 15:15:
CSP.sys doesnt work on it it seems, hangs on that. Probably missing that code.
I had a feeling this was coming
Reply 578 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-04, 15:18:
4.13 can be retropatched from 4.16, if 4.16 solves single cycle dma bug
Reply 579 of 1053, by S95Sedan
Works on the ct1740.
Diagnoses like usual.
DMA clicking is something else, still present unfortunately.
https://streamable.com/z0vg97
