Reply 560 of 1120, by georgel
Maelgrum wrote on 2023-10-04, 14:37:0xC0 at command loop 0xC2 at entering midi loop 0xC4 in midi byte write routine […]
georgel wrote on 2023-10-04, 14:29:What do you assume SP to be at MIDI byte write routine in 4.16?
Sorry , I meant the word pointed by SP=C4 at MIDI byte write. The above is the same in every version.
