Reply 620 of 1129, by S95Sedan
Maelgrum wrote on 2023-10-05, 13:13:sbcrack stage 2 for 4.12
For 4.12;
Stage 2, variant 05 ...passedStage 2, variant 07 ...passedStage 2, variant 18 ...passedStage 2, variant 44 ...passed
For 4.12;
sbcrack stage 3 for 4.12
Maelgrum wrote on 2023-10-05, 14:04:sbcrack stage 3 for 4.12
SB Reset: doneDSP version: 4.12MPU-401 init: doneMPU-401 loopback check: doneStage 3, variant 44 ...passedSuccess!
Stack structure for variant 44:
C0 ACC
BF R0
BE DPH
BD DPL
BC ACC
BB PCH
BA PCL
looks good for attack ))
sbcrack stage 4 for 4.12
Maelgrum wrote on 2023-10-05, 14:27:sbcrack stage 4 for 4.12
SB Reset: doneDSP version: 4.12MPU-401 init: doneMPU-401 loopback check: doneStage 4, addr 1212 ...failedStage 4, addr 1213 ...failedStage 4, addr 1211 ...failedStage 4, addr 1214 ...failedStage 4, addr 1210 ...failedStage 4, addr 1215 ...failedStage 4, addr 120F ...Success!
S95Sedan wrote on 2023-10-05, 14:30:Maelgrum wrote on 2023-10-05, 14:27:sbcrack stage 4 for 4.12
Stage 4, addr 120F ...Success![/code]
Excellent !
Stage 5 not required - all checks are integrated in stage 4
sb16dump will be ready soon
sb16dump V0.14 experimental support for 4.12
Maelgrum wrote on 2023-10-05, 14:44:sb16dump V0.14 experimental support for 4.12
Gives an error.
Added the mdump1 and 2.
SB Reset: doneDSP version: 4.12MPU-401 init: doneInternal memory dump: doneMPU-401 loopback check: doneERROR: Dump failed
some more sbcrack scan Stage4
scans full possible range
You had the same problem yesterday with 4.16. Keep in mind that considering resetting of DSP and returning of AA as a proper result is on my opinion very wrong. Resets can be triggered by faulty code too. Wrap around to address 0 past program memory would result in reset too. But 120F looks very probable for an address of E3 comparing it to 4.13. Instead I propose you to look for the proper functioning of E3, e.g. returning of copyright $.
Maelgrum wrote on 2023-10-05, 14:59:some more sbcrack scan Stage4
Same result all failed apart from the one that already passed. (120F )
sb16dump V0.15 experimental support for 4.12 (found error in previous version)
Maelgrum wrote on 2023-10-05, 15:08:sb16dump V0.15 experimental support for 4.12 (found error in previous version)
Same as the other version.
Added Mdumps.
This triggered an NMI for me on my AWE32
maxtherabbit wrote on 2023-10-05, 15:27:Maelgrum wrote on 2023-10-05, 15:08:sb16dump V0.15 experimental support for 4.12 (found error in previous version)
I guess it jumps to a code which generates NMI for MIDI emulation with AWEUTIL.
That happened to me when testing with SBCRACK and dumping the firmware for the AWE64 CT4520.
Just disable NMI to let it continue and do a cold boot afterwards.
I do not have the ability to disable NMIs on this board short of putting a piece of tape on the card edge or something
Apparently you can gate them by setting bit 7 at I/O port 0x70.
Now it's just ERROR: Dump failed
Perhaps toggling the MFBEN jumper setting helps?
maxtherabbit wrote on 2023-10-05, 15:51:I do not have the ability to disable NMIs on this board short of putting a piece of tape on the card edge or something
Yes , tape would work perfectly. It is the rightmost pad on the XT edge connector but I guess you know that.
