The Soundblaster DSP project
Reply 620 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 13:13:
sbcrack stage 2 for 4.12
For 4.12;
Stage 2, variant 05 ...passed
Stage 2, variant 07 ...passed
Stage 2, variant 18 ...passed
Stage 2, variant 44 ...passed
    LOG.TXT
    2.06 KiB
    27 downloads
Reply 622 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:04:
sbcrack stage 3 for 4.12
SB Reset: done
DSP version: 4.12
MPU-401 init: done
MPU-401 loopback check: done
Stage 3, variant 44 ...passed
Success!
Reply 625 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:27:
sbcrack stage 4 for 4.12
SB Reset: done
DSP version: 4.12
MPU-401 init: done
Stage 4, addr 1212 ...failed
Stage 4, addr 1213 ...failed
Stage 4, addr 1211 ...failed
Stage 4, addr 1214 ...failed
Stage 4, addr 1210 ...failed
Stage 4, addr 1215 ...failed
Stage 4, addr 120F ...Success!
Reply 626 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-05, 14:30:
Stage 4, addr 120F ...Success![/code]
Excellent !
Stage 5 not required - all checks are integrated in stage 4
sb16dump will be ready soon
Reply 628 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:44:
sb16dump V0.14 experimental support for 4.12
Gives an error.
Added the mdump1 and 2.
SB Reset: done
DSP version: 4.12
MPU-401 init: done
Internal memory dump: done
ERROR: Dump failed
    dump.zip
    642 Bytes
    24 downloads
Reply 630 of 1053, by georgel
You had the same problem yesterday with 4.16. Keep in mind that considering resetting of DSP and returning of AA as a proper result is on my opinion very wrong. Resets can be triggered by faulty code too. Wrap around to address 0 past program memory would result in reset too. But 120F looks very probable for an address of E3 comparing it to 4.13. Instead I propose you to look for the proper functioning of E3, e.g. returning of copyright $.
Reply 631 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 14:59:
some more sbcrack scan Stage4
scans full possible range
Same result all failed apart from the one that already passed. (120F )
    LOG.TXT
    2 KiB
    25 downloads
Reply 633 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 15:08:
sb16dump V0.15 experimental support for 4.12 (found error in previous version)
Same as the other version.
Added Mdumps.
SB Reset: done
DSP version: 4.12
MPU-401 init: done
ERROR: Dump failed
    dump.zip
    646 Bytes
    23 downloads
Reply 634 of 1053, by maxtherabbit
This triggered an NMI for me on my AWE32
Reply 635 of 1053, by georgel
maxtherabbit wrote on 2023-10-05, 15:27:
I guess it jumps to a code which generates NMI for MIDI emulation with AWEUTIL.
Reply 636 of 1053, by Gmlb256
That happened to me when testing with SBCRACK and dumping the firmware for the AWE64 CT4520.
Just disable NMI to let it continue and do a cold boot afterwards.
Reply 637 of 1053, by maxtherabbit
I do not have the ability to disable NMIs on this board short of putting a piece of tape on the card edge or something
Apparently you can gate them by setting bit 7 at I/O port 0x70.
Now it's just ERROR: Dump failed
Reply 639 of 1053, by georgel
maxtherabbit wrote on 2023-10-05, 15:51:
Yes , tape would work perfectly. It is the rightmost pad on the XT edge connector but I guess you know that.
