Reply 180 of 215, by Gmlb256
mockingbird wrote on 2023-08-31, 13:29:Gmlb256 wrote on 2023-08-31, 13:18:This is one of the reasons why I set the FSB/PCI to 124/31 MHz on mine instead of 133/33 MHz. With 133 MHz FSB (aside from the issue with the AGP @ 89 MHz), I had to set the VIO jumper setting to Test for stability and that wasn't great for the northbridge's lifespan.
Interesting... Maybe the 440ZX was less capable in that regard. It wasn't only the heat coming out of the northbridge, the CPU @ 1.6V was an order of magnitude hotter than it was when it was running at 1Ghz. 0.15V shouldn't have that effect. This silicon just wasn't meant for that. The clockgen is also hot -- I might put a heatsink on it. See the second edit of my post above about Prime95, btw.
Finally managed to get 133 MHz FSB stable without toggling the VIO jumper by replacing the PC133 SDRAM sticks with higher quality ones from Infineon that I got during week. The previous ones used Micron chips and apparently, they weren't up to the task regardless of the CAS latency settings.
To handle the AGP @ 89 MHz, I'm now settling for a GeForce2 GTS card which turns out that the VBIOS it has doesn't support sideband addressing.
I have now added a signature that shows the specs of my current and now only retro computer. Wish that the vintage edition of CPU-Z let me validate it.
