Reply 180 of 224, by Gmlb256
mockingbird wrote on 2023-08-31, 13:29:
Gmlb256 wrote on 2023-08-31, 13:18:
This is one of the reasons why I set the FSB/PCI to 124/31 MHz on mine instead of 133/33 MHz. With 133 MHz FSB (aside from the issue with the AGP @ 89 MHz), I had to set the VIO jumper setting to Test for stability and that wasn't great for the northbridge's lifespan.
Interesting... Maybe the 440ZX was less capable in that regard. It wasn't only the heat coming out of the northbridge, the CPU @ 1.6V was an order of magnitude hotter than it was when it was running at 1Ghz. 0.15V shouldn't have that effect. This silicon just wasn't meant for that. The clockgen is also hot -- I might put a heatsink on it. See the second edit of my post above about Prime95, btw.
Finally managed to get 133 MHz FSB stable without toggling the VIO jumper by replacing the PC133 SDRAM sticks with higher quality ones from Infineon that I got during week. The previous ones used Micron chips and apparently, they weren't up to the task regardless of the CAS latency settings.
To handle the AGP @ 89 MHz, I'm now settling for a GeForce2 GTS card which turns out that the VBIOS it has doesn't support sideband addressing.
I have now added a signature that shows the specs of my current and now only retro computer. Wish that the vintage edition of CPU-Z let me validate it.
Reply 181 of 224, by BitWrangler
Were they micron modules or 3rd party? Might have been remarked from 8ns... (Though I've had plenty of 8ns do 133 on Cas3)
Reply 182 of 224, by Gmlb256
BitWrangler wrote on 2023-10-14, 23:19:
Third-party with 4 Micron chips on each side and those weren't stable at CAS3 settings when running the FSB at 133 MHz.
Reply 183 of 224, by mockingbird
Gmlb256 wrote on 2023-10-14, 23:02:
Very nice, good work... I had no luck at all with Infineon chips for some reason, but most other stuff worked fine... Keep an eye on the northbridge temperature... I'd put a heatsink on it at the very least at 133Mhz if there isn't one already.
(Decommissioned:)
Reply 184 of 224, by BitWrangler
That's what gobbled up most of my original stock of 486 and early pentium heatsinks back in the day, 1998-2003 northbridge cooling.
Reply 185 of 224, by ifrit05
What is a safe voltage range for Neh.'s? I got my 1.0 to 1.26 but anything over that it becomes unstable.
P3B-F v1.03 | VIA C3 Nehemiah 1.0A @ 500/66 | 128 PC133 | GeForce 256 SDR | PicoGUS+Yamaha OPL3-SAx | FreeDOS 1.3
Reply 186 of 224, by Gmlb256
ifrit05 wrote on 2023-11-03, 14:59:
The rated CPU core voltage is around 1.4v - 1.45v, but it can be bumped to 1.5v safely if the overclock is unstable.
Edit: According to the "Recommended Operating Conditions" in the VIA C3 Nehemiah Processor Datasheet, the safest voltage range is 1.365v - 1.635v on Socket 370 motherboards and slotket adapters that doesn't support Tualatin.
Edit #2: That was the CPU voltage termination range what I mentioned in the first edit. 😜
Reply 187 of 224, by ifrit05
Gmlb256 wrote on 2023-11-03, 16:20:
The rated CPU core voltage is around 1.4v - 1.45v, but it can be bumped to 1.5v safely if the overclock is unstable. […]
Thanks.
I tried 1.33@1.5v, 3DMark 2001SE crashed then 99/00/01 said I didn't have a DX6/7/8.1 GPU... So I went back down to 1.26@1.45v.
EDIT: Seems like 1.7v is the absolute maximum core voltage. I guess I can try 1.55v.
Reply 188 of 224, by bloodem
My two best Nehemiah CPUs (which are 1.2 GHz SKUs), can reach a stable 1.53 GHz @ 1.55V. That's a 27% overclock.
The other five can only go up to 1.46 GHz (21% overclock).
So, if your 1 GHz Nehemiah is stable at 1.26 GHz (26% overclock), that's actually quite good and in line with what my best chips can do.
Going beyond that is probably very difficult to achieve with a 1 GHz part (i.e.: you'd have to win the silicon lottery big time!).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 189 of 224, by ifrit05
bloodem wrote on 2023-11-04, 17:17:
My two best Nehemiah CPUs (which are 1.2 GHz SKUs), can reach a stable 1.53 GHz @ 1.55V. That's a 27% overclock. The other five […]
Well it seems my P3B-F doesn't quite like booting reliably at 133MHz, so I lowered it to 100MHz with a 13x multi @ 1.45. Seems to be pretty stable now, although not sure how much the lower FSB is a bottleneck now, but the whole point was to have a scalable CPU for older DOS games.
Reply 190 of 224, by Gmlb256
ifrit05 wrote on 2023-11-05, 15:13:
It depends on the quality of the SDRAM sticks, previously I used two cheap PC133 ones that weren't stable at 133 MHz FSB, no matter how the CAS latency settings were set in the BIOS.
There will be some performance left on the table due to lower RAM bandwidth. It is still plenty for many DOS games though.
Reply 191 of 224, by ifrit05
Any tips on finding a good brand?
Reply 192 of 224, by Gmlb256
ifrit05 wrote on 2023-11-05, 15:34:
At the time of this writing, there is currently a guy on eBay selling pairs of Infineon 128MB PC133 SDRAM CL2 sticks.
Reply 193 of 224, by ifrit05
16x64 is good? Or do I need to look for 16x32 for a 440BX board?
Reply 194 of 224, by Gmlb256
Those 128MB Infineon SDRAM sticks are single-sided with 8 chips (128 Mbit density), which are good enough for a motherboard based on the Intel 440BX/ZX chipset.
Reply 195 of 224, by Jackal1983
Ok, so I'm finishing up (assuming the only glitch is a whiny bios that tells me to set the right multi) an Ezra-T based "time machine"/ early 3D gaming rig with a Voodoo 3 and I'd like to know which MiniGL works best with and takes advantage of the C3's 3Dnow implementation. So far it looks like the stock opengl in the driver package works best which kind of confounds me.
Edit: Nevermind, noticed the board was overvolting the Ezra-T to an uncomfortable degree (1.5 volts!) so I swapped in a 1.2 GHZ Nehemiah.
Reply 196 of 224, by mockingbird
Can I get a sanity check please? Is Quake3 1.32 (or 1.32C) incompatible with the Ezra-T (or similar?). I get constant crashing while trying to run timedemo, but it works fine with the earlier release. Benchmark should be 1024x768, everything maxxed out and both color depth and texture depth set to 32-bit. Tried with several different nVidia GPUs. Running DirectX 7a with 45.23 Detonator drivers.
Thanks
EDIT: hmmm, no, it's not the CPU. I just popped in a P3 and the same thing happened.
(Decommissioned:)
Reply 197 of 224, by bloodem
mockingbird wrote on 2024-02-08, 04:51:
Thanks
Sound card? Any other device?
Remove everything that you don't need and try again. 😀
Also, is this a 440BX motherboard or VIA Apollo Pro 133?
Reply 198 of 224, by mockingbird
bloodem wrote on 2024-02-08, 15:35:
Nothing -- bone stock 440BX system. I think I have it narrowed down -- I'll report back soon.
(Decommissioned:)
Reply 199 of 224, by BitWrangler
Got any USB cards in it? That's a frequent bugbear.
