First post, by songoffall
So I found this tiny thing in a bunch of e-waste.
As you can see, the chip is marked as a YMF744B-R. At this point I expected it to be a fake - CMI8738/C3DX repainted as Yamaha. But there's an easy way of checking - Yamaha's drivers won't work with CMI8738/C3DX. So I got the Windows drivers from Phil's Computer Lab. And they worked. Now I'm even more confused. This does not look like a Yamaha YMF744 card. But it is one. It even detects a game/MIDI port, even though the card has none.
Have you ever seen one like this?
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 1 of 52, by paradigital
What a neat little thing! Never seen one before. I’d imagine that the IC is that highly integrated that the gameport logically exists.
Is the sound quality any good?
Reply 2 of 52, by kingcake
Wow that's the most cost reduced Yamaha card I've seen. Didn't even include the CD Audio header. Can you show us the back?
Reply 3 of 52, by songoffall
kingcake wrote on 2023-10-29, 07:55:
Sure, friend.
I went ahead and soldered a connector so the card had a CD header.
Haven't tested the sound yet. Will do later in the day or tomorrow.
Reply 4 of 52, by songoffall
paradigital wrote on 2023-10-29, 07:47:
Will do later, need to set a system up for testing.
I had never seen one either. I added a CD Audio connector, because some DOS games require CD Audio, and I've heard YMF744 is one of the better PCI DOS cards.
Reply 5 of 52, by songoffall
songoffall wrote on 2023-10-29, 08:15:
Will do sound test later, need to set a system up for testing.
Reply 6 of 52, by songoffall
Ok, I confirm that the sound is more or less what you would expect from a Yamaha card. It's not bad at all.
Reply 7 of 52, by rasz_pl
Cant tell from the picture, what is the model/brand of AC97 codec chip? Sadly Yamaha works entirely in digital domain here and doesnt influence sound quality, that depends entirely on codec, power delivery and pcb design.
Reply 8 of 52, by Bondi
songoffall wrote on 2023-10-29, 18:01:
I don't quite remember, does YMF744B support MIDI in DOS? Or it supports only OPL3 in bare ODS, and MIDI in Windows?
Also I've read elswhere that fake cards don't have the codec chip, as they are based on CMI8738 that has an integrated codec.
So it's another way to confirm your card isn't a fake.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 9 of 52, by songoffall
Bondi wrote on 2023-10-29, 19:06:
I don't quite remember, does YMF744B support MIDI in DOS? Or it supports only OPL3 in bare ODS, and MIDI in Windows? Also I've […]
The Yamaha codec is detected in Windows. I tested OPL3 in DOS only. Guess I have to run some more tests.
Reply 10 of 52, by songoffall
So I went forward and checked the other chips on the cards. There's a chip marked AD1888, and googling it, it's a SoundMax AC97 codec. Don't know if it's any good, but it is what it is. So, again, everything checks out - it is a Yamaha YMF744B.
Still have to run the other tests though. If you have suggestions for settings/software to use for testing, I'm all ears.
Reply 11 of 52, by songoffall
All three ICs on the board:
YMF744B-R - Yamaha XG YMF744, some version of it
AD1888 - SoundMax AC97 Codec
455BD - Timer
Reply 12 of 52, by songoffall
At this point I'm tempted to send this card to Phil's Computer Lab or Clint at LGR and have it properly tested and examined 😀) I don't think my experience and setup will do it justice, especially if it's really a rare card.
Reply 13 of 52, by dionb
It's not rare. It's a new 'Chinese' card made incredibly cheaply with overstock old chips. Similar cards are churned out in massive numbers with various old chips on them, frequently relabeled too (i.e. with something written on the chips that does not correspond to the actual chip itself). You can pick them up on eBay and Aliexpress.
Can't say I've seen this exact one before but the concept is ubiquitous. At least that chip looks like it could actually be a Yamaha PCI chip...
Reply 14 of 52, by songoffall
dionb wrote on 2023-10-30, 07:49:
I've confirmed it's an actual Yamaha chip, but the thing still confuses me. At this point most motherboards have more or less decent onboard audio and even surround options.
Reply 15 of 52, by songoffall
But you're spot on about the origin of the card, I just searched Aliexpress and came across the same card, but with an ESS chip:
https://aliexpress.com/item/1005005987920346. … .3a704aa6KW9Ici
Reply 16 of 52, by darry
songoffall wrote on 2023-10-30, 12:17:
Most motherboards manufactured in the last 10 years or so do not have legacy PCI slots, so cards like this are not meant for them.
I would guess that the most common use case for something like this is as a replacement part for a legacy system that is still in use in a commercial or industrial setting. The fact that it can be used for retro gaming is just a bonus to us.
Reply 17 of 52, by songoffall
darry wrote on 2023-10-30, 12:50:
I'm happy to take a bonus like that 😀)
Reply 18 of 52, by rasz_pl
songoffall wrote on 2023-10-30, 12:21:
Cyfrowa-karta-d-wi-kowa-PC-Wbudowana-5-kana-owa-karta-rozszerze-audio-stereo-PCI-E.jpg_.webp
Neat bracket mounting compared to OPs card, by extending single screw mount they were able to get rid of upper board protrusion thus you can fit more boards on one PCB panel. Good example of smart DFM (Design for Manufacturing), this is cost optimized to the bone.
Reply 19 of 52, by darry
An ESS chip in the photos, a C-Media one in the description. 😉
