First post, by JRRTolkien
Hi, I tried to run this game on Windows 10, I installed the silent patch, but I still have problems making it work correctly, the game crashes in the character creation screen, does anyone know how to fix it?
The error occurs in all versions except the English, it is the front_pc.str file, each language has its own front_pc.str file, I cannot help you, I have no knowledge to modify the file or the nocd patch.
There are many people waiting to solve the error to play, where I include myself.
If you want to play, but without a guarantee of being able to finish the game, you can use the Frontend_PC.STR file in English and although it will not show any text can be intuit and when you can save, you change the file again by border_pc.str Italian.
I have uploaded the files to Mediafire in case someone wants to look at them.
https://www.mediafire.com/file/o96vjcsi8f72v8 … father.rar/file
Greetings.
I have the Italian version of the game and in addition to replacing the fronted_pc.str file I carried out a second procedure to try to make the change permanent, but I was only partially successful. I renamed the files in the fronted_pc\text folder with the codes of the files from the American version of the game, then I did the same thing for three of the six files in godfather_v4\text and then I also replaced the pause_pc file. Finally I edited the localtable.txt text file and changed the language to "en" in the first string.
Now I have the Italian texts that appear everywhere and the game doesn't crash when character creation. Until now I have noticed that not only the names of the NPCs are displayed, I think that to definitively resolve the only way is, as you well said, to modify the fronted_pc.stl file using an .stl editor software, I looked for some guide and I found this, I don't want to spend any more time, but maybe you can try it if you want:
https://www.reddit.com/r/battalionwarsmod/com … tr_file_editor/
https://www.nexusmods.com/thegodfather/mods/6/
I'm glad you can play, thanks for the information, but Python and Pyqt ... is too complex to me.
Greetings.
Hey JRRTolkien, I have the same problem and I haven't found any fix. I have Polish version, the tutorial works etc. but I also can't name the character. Could you please share with me the codes of the files from the American Version? Or where to find them?
Hi its old thread i know but have same error. While creating character name game crashing to desktop. Using english version (us think)
from pcgaming wiki, i don't know if it helps:
After renaming movies folder, character can not be named after creation
A problem caused after applying SilentPatch into the European version of the game
Workaround
Create a save file in the original European godfather.exe without any mods.
Find a US executable that will enable SilentPatch to work, and replace the existing one.
Rename the _Movies folder back to Movies.
Move the save file from %USERPROFILE%\Documents\corleone to %USERPROFILE%\Documents\GF\SG\.
