Reply 40 of 55, by DerBaum
This piece of OPL music always stayed in my head. It was the first time i heard speech generated by a sound card.
https://youtu.be/YPNV0BG1R0M?si=ud8-j8AjBwk89VwM&t=60
Today i can understand how different sounds can sound like a voice, but back in the days as a 12 year old i was pretty impressed... Actually i am still impressed...
FCKGW-RHQQ2
Reply 41 of 55, by binarymaster
Bondi wrote on 2023-11-06, 11:06:
The games I could find that supported this trick. I believe some (all) of them were previously mentioned already. - Sango Fighte […]
- Sango Fighter (a new (version?)game from 2010)
- Stunt Driver
- Pinball fantasies
- F-15 Strike Eagle II
EDIT: - Fastdoom mod also supports FX sound via Adlib (with no music in the background, though)
The method itself is described here in all details https://github.com/leonardo-ono/Assembly8086P … dSoundAdlibOpl2
Doom 2D also could use AdLib as DAC for both sound and music (though it's all for digitized sound, they didn't used FM synthesis).
Reason: removed warez site link
by Stas'M
Reply 42 of 55, by Bondi
digger wrote on 2023-11-06, 15:17:
- Stunt Driver
- Pinball fantasies
Thanks for the list, Bondi. Do you happen to know which of these also supported digital samples combined with FM music, using this method?
This would be an interesting case for viti95 to take a look at, maybe. 🙂
I tried Pinball fantasies and it doesn't combine music and sound effects. It plays mod music at the intro and does only sound effects during gameplay. EDIT: Pinball fantasies actually has an option to enable in-game music. So it does produce music and effects simultaneously.
I don't have the other games installed, but iirc none of them has background music when using Adlib for sound effects.
I can also confirm that Doom2D has Adlib PCM support, as binarymaster mentioned.
Besides I tried Tubular worlds(I liked it very much, btw) and Prince of Persia, it's hard to tell, but my feeling is that they don't actually play PCM sounds, but use usual FM for very basic beeps and boops, like ROTT, Cannon Fodder and many other games.
EDIT2: Another game I found is LHX: Attack Chopper
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 43 of 55, by Bondi
Found three more games:
- Electro Man (also known as Electro Body)
- Heartlight
- The Adventures of Robbo
I couldn't get the last one running with sound, but that's probably due to my (PCMCIA) setup or a cracked game version. All 3 games come form the same studio and have identical sound setup program. The other two worked fine.
EDIT: Three more candidates, still need to check:
- Space Ace
- Bill & Ted's Excellent Adventure
- Wizardry: Crusaders of the Dark Savant
Reply 44 of 55, by ViTi95
FastDoom supports sound + digitized music with a single OPL2 chip (ISA and OPLxLPT). The code is all written in C so it's easier to read:
https://github.com/viti95/FastDoom/blob/maste … DOOM/ns_adbfx.c
It's a bit faster on ISA cards, as the OPLxLPT devices require additional writes to the parallel port.
https://www.youtube.com/@viti95
Reply 45 of 55, by digger
@ViTi95 I assume with "digitized music" you mean tracker music as opposed to FM music?
I'm still wondering whether it would be feasible to combine PCM sound effects with FM music playback, at least on an OPL3, which has twice the number of channels as an OPL2 and also doesn't need long delays between port writes like the OPL2 does.
Reply 46 of 55, by ViTi95
Tracker music is more CPU intensive than playing directly raw PCM music, so I ended up using raw PCM music for FastDoom.
Reply 48 of 55, by jtchip
Links 386 Pro supports Adlib for PCM sound effects (it does not have music).
Reply 50 of 55, by Linoleum
I believe the diskette version of X-Wing does... There is Hardball III also.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 51 of 55, by leileilol
X-Wing will switch to adlib sounds automatically when there's not enough memory or if there's a pcm sound currently playing
FUCK "AI"
Reply 52 of 55, by Gmlb256
Jetpack supports AdLib for non-digitized sound effects and doesn't have any background music. Certain sound effects still only played thru AdLib when a SB compatible sound card is present, akin to Wolfenstein 3-D and Blake Stone.
Reply 53 of 55, by creepingnet
I know SCUMM has already been mentioned, but the original VGA Release of The Secret of Monkey Island does this - 1990 - the one with the green text and the purple text-only inventory. Ultima VII parts 1 & 2 also supported sound effects via Adlib as well. Sometimes I'm forced to use that configuration because of the bloody memory management nightmare VooDoo is. I think a lot of Origin and LucasArts releases are like this.
SoMI has a hilarious door close sound on OPL, sounds like someone putting a cork in a bottle: Chef "Stay outta' the kitchen (Boomp)"
~The Creeping Network~
Reply 54 of 55, by Riikcakirds
Jurassic Park you can set up Adlib for SFX and SB/MT32/SC for music.
Reply 55 of 55, by Bondi
Riikcakirds wrote on 2023-12-19, 00:27:
I tried JP, but it unfortunately doesn't actually play PCM sound via Adlib, it uses FM for SFX. If I set SB for SFX it sounds quite differently.
A nice game nevertheless. But the character runs very slowly (on a 486 DX50). Is it supposed to be like that? Same is in DosBox.
