My 3DMark01 Mega Thread
Reply 800 of 867, by Ikkyusan97
Intel Core i5-13500 / AMD Radeon RX 6600 / Windows 11 23H2 (22631)
RX 6600 @ Stock clock file.php?mode=view&id=179686
RX 6600 OC @ 2825 MHz core / 1900 MHz mem / 1600 MHz SoC / 2120 MHz FCLK file.php?mode=view&id=179687
Reply 801 of 867, by Dothan Burger
i7 1270KF stock
RTX 3070 founders stock
Reply 802 of 867, by mln
Xeon X5675 3.07 GHz (1 core used by Win98)
48GB DDR3 RAM (512 MB used by Win98)
Radeon X800
Windows 98
No OC, default benchmark
Reply 803 of 867, by Alan Nolath
Hello guys, Second post from my P4-X1950Pro AGP With improvement Scores
Motherboard - Asrock P4i65G
CPU - Pentium IV Prescott 3.0Ghz HT (PGA478) (OC To 3.6Ghz)
RAM - Kingston 512Mb x2 ddr400 (1GB) (Dual Channel)
GPU - Ati Radeon x1950 Pro AGP 512mb GDDR3 (Stock Clock)
Windows xP Home Edition SP3 32bit (This it's new post after first with the same computer. Now with a Pentium IV less Hz than the 1st but highly Overclocked)
(First PNG it's from the Stock CPU settings (3.0Ghz))
The attachment x1950 pro AGP & P4-478 3.0Ghz.png is no longer available
(Second PNG it's from the Overclocked CPU Settings [3.6Ghz])
The attachment x1950 pro AGP & P4-478 3.6Ghz OC II.png is no longer available
i've Waiting for a Northwood 3.2 HT Cpu bought from EBAY.... I will testing when gets delivery at my home
(Please if anybody wants to answer a question..... It's true that prescott it's very hot like people remember? My p4i65G MB Does not reach 50 degress in CPU Temp sensor at hwinfo. i has a zalman cnps7000a-cu Cooler with Max RPM in Fan Regulator)
Reply 804 of 867, by DarthSun
Loose tuning to the GTX770 under xp. I glued the separating tags with other labels.
The attachment 3800x_gtx770_4625_3dm2001_1deskdual.jpg is no longer available
The attachment pejv_1_gtx770_cmod.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 805 of 867, by ErroneousHyphen
I'll have to grab a screenshot and update, but at the moment with my P4 661 3.6Ghz OC'd to 4.24Ghz
and Radeon 9800 OC'd to 425.25Mhz/357.75Mhz for GPU/Memory respectively Im running at
21686 3dMarks from 2001SE
Reply 806 of 867, by Shagittarius
ErroneousHyphen wrote on 2024-10-12, 10:45:
That's pretty much a maxed out 9800 Pro, about 22k.
Reply 807 of 867, by ErroneousHyphen
Shagittarius wrote on 2024-10-12, 15:37:
So you'd say I'm bottlenecked by the CPU do you mean?
Reply 808 of 867, by DarthSun
Core2Duo/QFX3500(7900GS):
The attachment E8500_QFX3500_3DM01.jpg is no longer available
Reply 809 of 867, by Shagittarius
ErroneousHyphen wrote on 2024-10-13, 05:49:
No I would say that's about as fast as a 9800 Pro will ever go.
Reply 810 of 867, by ErroneousHyphen
Shagittarius wrote on 2024-10-13, 17:36:
Ohh I getcha - yes it was only a relatively lazy OC for me, but I don't imagine I'll be able to push it much further without it starting to crash or overheat. I will get back to it someday soon to see if I can squeeze a little extra out of it but I think at this point it will be very small increases.
Reply 811 of 867, by Ozzuneoj
Does anyone know if there is a way to edit the "Description" saved into 3dmark 2001SE .3dp benchmark result files? There doesn't appear to be any way to actually edit the file itself. I have tried using Results Browser (which is an awesome piece of software for 2001 IMO) but it only allows you to change the description shown in that database, not in the individual.3dp files.
My issue is that over several years I have saved 3dmark results on dozens of GPUs I have tested in one of my machines and I only very recently realized that they all show up as "My Benchmark" when imported into the results browser. The file names all describe what they are, so I can easily just migrate that information over to the "Description" if I can just find a way to edit them.
If I have to, I will use a hex editor. This was many years of tests and I'd actually like to post the results in a thread at some point. It'd be nice to be able to have different databases of results shown without having to rename each result for each group of comparisons.
Reply 812 of 867, by agent_x007
You should put whatever you want into that field BEFORE you run the benchmark.
After which you should be able to change it in Result Browser ?
The attachment What ever name.png is no longer available
^Just double left click on name (red arrow), and change name/description.
Reply 813 of 867, by Ozzuneoj
agent_x007 wrote on 2024-11-23, 13:44:
Yes, I know that now, but that doesn't fix the multiple years of benchmarks that I ran before I knew that.
Since these results were gained by testing a card to see if it would pass, it was a bit impractical to enter all of the information for every card before knowing whether it would work or not. I try to enter things like core and memory clock speeds, memory bus width, etc. So it isn't a trivial amount of data to have to find and then enter if a card ends up not making it through the whole test.
Sadly, this doesn't change the file itself. This only changes the information associated with that .3dp file within that database. The bandaid solution to this, of course, would be to enter all of the information for all of the cards in a single database and then just make copies of the results to other databases, but that just makes my brain hurt a bit from a data-collection or data-preservation perspective, since the original results files will always be missing this information.
I was really hoping I was just missing some part of the Results Browser or some third party program that would allow me to edit the description after the fact.
Reply 814 of 867, by agent_x007
If you want to change name of the .3dp file... can't you just do it via Windows usual "change file name" method ?
I don't think I understand where you "can't change file name"... well here's a sample of throwing multiple .3dp files into one and saving that as seperate (I think you mentioned it) :
The attachment Test comparison.png is no longer available
As for "full card details", .3dp doesn't have a way to change "Rendering platform" field... because that would be "cheating" in a major way.
Can you make a screenshot and point where you want to add your notes, but are unable to ?
I simply fail to understand your issue at this point (I need some visual clues).
Reply 815 of 867, by Ozzuneoj
agent_x007 wrote on 2024-11-24, 11:24:
If you want to change name of the .3dp file... can't you just do it via Windows usual "change file name" method ? I don't think […]
Yeah, I never said anything about changing the file name. And I'm not trying to change any of the system data gathered by the program.
In my first post about this I said:
Does anyone know if there is a way to edit the "Description" saved into 3dmark 2001SE .3dp benchmark result files? ... they all show up as "My Benchmark" when imported into the results browser.
If you do not fill in the "description", it is left as "My Benchmark". And this is saved to the .3dp file the moment you save it after running the benchmark. If you have 50 files where this hasn't been changed, you end up with this (pretend the results are different... all of the old benchmarks aren't on this PC right now.)
The attachment Screenshot 2024-11-24 064436.jpg is no longer available
The attachment Screenshot 2024-11-24 064412.jpg is no longer available
If I edit the description and click "save", it only saves these modifications to the database, not to the .3dp file.
So, for example, I have edited the description to provide pertinent data (RTX 3080 TUF (UV)), saved the database, and if I add the same .3dp file to this database again or to another database for different comparisons, the description is still "My Benchmark", because there is no way to save the changes to the .3dp file.
The attachment Screenshot 2024-11-24 065919.jpg is no longer available
This shouldn't be a matter of preventing cheating, since anyone can change the "description" and "comments" saved in the database, and back when the online results could still be submitted, you could submit your results from the "Results Browser" with whatever you typed into those fields.
I just posted here to see if anyone knew of a way to edit the description (My Benchmark) that is saved to the .3dp file itself so that it would always be a part of the file, and, if I ever decide to add more descriptive information to all of these benchmark results files I could do so.
If no one has ever figured out a way to do this, it is most likely because the files are encoded so that absolutely nothing can be modified... but people figure out weird things like this all the time, so who knows? 😀
Reply 816 of 867, by agent_x007
Ah, now I get it. Sadly that's not possible. Even in Hex edit 🙁
You COULD however open each .3dp in result browser, change whatever you need, and save that as new .3db file.
Changes to description will be saved in this new file (you can put it in the same folder as OG .3dp source).
The only inconvenience is that you have to move edited results from that .3db file, into the new database that is used for comparison each time you want to use those results (+ remembering to NOT override first .3db file you read).
Otherwise, by only adding edited .3db file, it will look just like the second screenshot in your above post (ie. without a way to get all scores in the same table)
Reply 817 of 867, by Ozzuneoj
agent_x007 wrote on 2024-11-24, 12:29:
Ah, now I get it. Sadly that's not possible. Even in Hex edit :( You COULD however open each .3dp in result browser, change what […]
Yeah, that is what I have basically accepted at this point. I will just maintain one database with all the correct descriptions contained in it.
At least the results browser allows multiple databases to be open at once in the file tree so I can just have one as the "main" database with all of the properly-described results, then just copy individual results to other databases for direct comparisons.
Again, it's mostly just one of those "but... but... I just... want the files to contain the correct data" obsessive data-managing mental things. Stuff like that really gets to me, and I am used to being able to correct most things like this via editing files somehow. This will probably stick in my craw for many more years. 🤣
EDIT: Also, I will put a sticky note on my test setup that says "3DMARK? = EDIT DESCRIPTION BEFORE SAVING!"... because I see that you can do that before saving the results after you have completed a test. I knew this button existed all along but I just never saw the point in doing it until I actually started messing with the results browser. It's a shame that the program uses the description as the label for each result on a chart, and you cannot tell it to use anything else for the label. Derp.
Hindsight! @_@
Reply 818 of 867, by GemCookie
MSI MS-5169 VER:2.1
AMD K6-2/350
Riva TNT2 M64
384 MiB PC100
Windows XP SP3
It took four times the estimated time, some parts ran at seconds per frame, but hey, it made it.
I've had the time of my life
I've never felt this way before
Yes, I swear, it's so true
I'm holding onto used hardware
Reply 819 of 867, by noshutdown
GemCookie wrote on 2024-11-28, 20:25:
MSI MS-5169 VER:2.1 AMD K6-2/350 Riva TNT2 M64 384 MiB PC100 Windows XP SP3 […]
MSI MS-5169 VER:2.1
AMD K6-2/350
Riva TNT2 M64
384 MiB PC100
Windows XP SP3
this is indeed a bit slow, i looked up my old results and found that i got nearly 900pts with k6-2-300(100*3) and geforce2ultra.
the video card surely makes some difference here, and i recommend using driver 30.82 for socket7 rigs with win2k/xp.
