Reply 26080 of 29186, by Thermalwrong
DerBaum wrote on 2023-11-28, 03:50:I see no reason why it shouldnt work. That looks great. :thumbsup: […]
Thermalwrong wrote on 2023-11-28, 03:36:Here's how the front and back look close up, ignore the possibly shorting loose traces wires, those will get secured once I know things work.
finished trace rebuild.jpgI see no reason why it shouldnt work.
That looks great. 👍edit: Ok maybe i see a reason near JYEN jumper... traces seem broken there
Well spotted 😀 I fixed that but I should've checked the hi-res PCB scans before attempting the rebuild, there was more broken including Address 7 on the ISA bus was severed further up by the 22X/24X jumpers. The initial test was rather disappointing.
appiah4 wrote on 2023-11-29, 11:01:Thermalwrong wrote on 2023-11-29, 03:08:Good news and bad news...... the ISA connector works though and it's not falling off. The glue is more of a space filler, those metal legs inside the fibreglass are giving all the important mechanical strength it needs, more now with the traces soldered on too.
And the bad news is?..
It's still broken of course! 😁
So there's good news and bad news because at this point I've verified that the card's FM part works, which is fantastic - that means the address and data pins on the ISA connector are working and the audio section is functioning. The YM3812 & Y3014 FM DAC are both functional. If that works, that means the CT1336 chip is doing its thing too, that's the important one since it can't easily be replaced.
The bad news of course is that the sound blaster isn't blasting, specifically the CT1351V201 chip isn't responding to any commands with the Snark Barker's SBDIAG test program, which absolutely should work even though it's designed for a Soundblaster 1.0/1.5 PCB. The crystal is resonating at 12MHz as it should and I'm pretty sure the power & data lines going to the DSP are all still good, so it should be working.
To test it some some more I pulled the chip back off and tested it with the TL866 where it seems to read okay as an AT89S51 but when I put the DSP onto my SB 2.0 clone card which conveniently has a socket, it fails in the same way as it does on the original card.
I'm pretty sure that the DSP on my clone card and the SB2.0 are interchangeable because it's a standard microcontroller and the Snark Barker reproduction's firmware on the github is the same as this card uses.
Next thing I'm gonna put a socket on the card and order some replacement PLCC44 AT89S51 chips 😀
