Reply 26100 of 29758, by mrfusion92
First power up of the DK440LX and, as most of you have guessed, it has two 266 Klamath cores.
PcBytes wrote on 2023-12-01, 09:18:(though with some patience and a bit of dremeling, I reckon it's possible to turn it into stereo).
Turning a mono machine into a stereo one may be a significant undertaking, the drum needs to have the 2 extra heads for stereo support to and any required chips in signal path present for it. Linear audio/mono signal path is completely separate from one of stereo.
smtkr wrote on 2023-12-01, 02:21:And what appears to be a distinctly Canopus graphics card (which one, I can't tell).
Geforce 2 MX400.
[/quote]
correct. Interestingly enough it nearly beats Canopus Spectra X20 Geforce3 in 3dMark 99 and 3dMark2000, need to do more tests.
Possibly with Pentium III 1GHZ SL4KL, as I used a PIII 800MHz for the dust off tests
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
mrfusion92 wrote on 2023-12-01, 12:16:First power up of the DK440LX and, as most of you have guessed, it has two 266 Klamath cores.
Really like this setup, have you tried a PIII 1GHZ dual CPU on Asus P2B-D or equivalent?
mrfusion92 wrote on 2023-12-01, 12:16:First power up of the DK440LX and, as most of you have guessed, it has two 266 Klamath cores. Screenshot 2023-12-01 12-49-09.png […]
Huh, the Slot 1 slots are reversed from pretty much any other board I've seen. I've seen regular and dual slot 1 boards with the slots perpendicular to this orientation, but never flipped like this.
Anyway, enjoy! I've got a dual slot 1 build that I got going a while ago and haven't really put it through its paces yet. Failed to get SMP Q3A running, I remember that...
vmr_ wrote on 2023-12-01, 15:25:mrfusion92 wrote on 2023-12-01, 12:16:First power up of the DK440LX and, as most of you have guessed, it has two 266 Klamath cores.
That's on my to do list, have a "fixer upper" P2B-D lurking around, two s370 1Ghz PIII and a number of slotkets to persuade into working with them. Not quite sure what gfx will go with it, I might give it a Gf3.
Thermalwrong wrote on 2023-11-29, 17:15:...is anyone interested in reproduction Soundblaster 2.0 PCBs? ...
I´ll take 2 plus shipping to germany.
FCKGW-RHQQ2
BitWrangler wrote on 2023-12-02, 02:55:vmr_ wrote on 2023-12-01, 15:25:mrfusion92 wrote on 2023-12-01, 12:16:First power up of the DK440LX and, as most of you have guessed, it has two 266 Klamath cores.
Hmm yeah, it was back in July - I got a couple slocketed Mendocino 533s going on an ASUS P2L97-DS. Ultimately didn't build a system with it, as I had a P2B-DS and higher sights. Currently that system has a couple SL457 P3-800s in it. I have a couple 1100MHz S370 SL5Q3s that I want to get in there, but I'm about 1 coppermine-compatible slocket short. I've been working on my soldering game, so it might be time to revisit modding one of my cheaper slockets...
Those P3 800s are so power efficient, though. 21W for 800EB vs. 33W for the 1.1GHz.
smtkr wrote on 2023-12-03, 01:07:Those P3 800s are so power efficient, though. 21W for 800EB vs. 33W for the 1.1GHz.
scaling is almost linear, at the time your desk lamp was burning at least 60W
Downloading bios files off a motherboard makers ftp in ch before they remove everything. Got a long was to go.....filezilla reports over 100Gb still in queue..ue..ue...ewu 🤣
added: currently working on soc 1150, 1151, 1155, 1156, will work on 2011 later. Looks like elhvb.com has most of the soc 462, 478, 775, 939, 1366 stuff...
Restored an HP Compaq nx9420 I have found at work.
I never had personally a 17'' notebook and I think this model is a very good specimen. It sports a Centrino Duo T2500 @ 2 Ghz, ATi Radeon X1600 (default res of 1440x900) and 3 GB of DDR2. With the help of the SSD now XP flies in this machine.
It's also very well built, nice full size keyboard and hinges are so sturdy.
Here it is running SimCity 4.
Horun wrote on 2023-12-03, 03:12:Downloading bios files off a motherboard makers ftp in ch before they remove everything. Got a long was to go.....filezilla reports over 100Gb still in queue..ue..ue...ewu 🤣
Thank you that! Please re host somewhere for everyone to have access
I was checking some K6 stuff and found that amd-k6.com isn't online anymore.
Hope anyone can shed some light.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Sphere478 wrote on 2023-12-04, 00:32:Horun wrote on 2023-12-03, 03:12:Downloading bios files off a motherboard makers ftp in ch before they remove everything. Got a long was to go.....filezilla reports over 100Gb still in queue..ue..ue...ewu 🤣
added: currently working on soc 1150, 1151, 1155, 1156, will work on 2011 later. Looks like elhvb.com has most of the soc 462, 478, 775, 939, 1366 stuff...Thank you that! Please re host somewhere for everyone to have access
fek ! last night grabbed all the 1150 and 1151, tonight it times out. I will try again tomorrow.
Nexxen wrote on 2023-12-04, 01:49:I was checking some K6 stuff and found that amd-k6.com isn't online anymore.
I just checked and it loads up some Chinese language site. Hopefully the original comes back as it was a great resource.
chrismeyer6 wrote on 2023-12-04, 02:09:Nexxen wrote on 2023-12-04, 01:49:I was checking some K6 stuff and found that amd-k6.com isn't online anymore.
Hope anyone can shed some light.I just checked and it loads up some Chinese language site. Hopefully the original comes back as it was a great resource.
Owner took it down: http://web.archive.org/web/20230608041646/htt … www.amd-k6.com/
you can browse a bit: http://web.archive.org/web/20221209160436/htt … www.amd-k6.com/
Working on a pair of builds: Pentium 200 and Pentium Pro 200.
Did some stress testing of each system for about an hour each to see how cooling performed and making sure they are stable.
ubiq wrote on 2023-12-02, 18:12:BitWrangler wrote on 2023-12-02, 02:55:vmr_ wrote on 2023-12-01, 15:25:Really like this setup, have you tried a PIII 1GHZ dual CPU on Asus P2B-D or equivalent?
What are those downright beautiful copper heatsinks? Would really match my P2B-DS and 2xCuMine 1.1 ... 😀
ubiq wrote on 2023-12-02, 00:35:mrfusion92 wrote on 2023-12-01, 12:16:First power up of the DK440LX and, as most of you have guessed, it has two 266 Klamath cores. Screenshot 2023-12-01 12-49-09.png […]
PXL_20231201_120042098.jpgHuh, the Slot 1 slots are reversed from pretty much any other board I've seen. I've seen regular and dual slot 1 boards with the slots perpendicular to this orientation, but never flipped like this.
Didn't notice that CPU placement before now, but yeah, I haven't seen Slot-1s with the fan turned to the back of the motherboard before, either ...
