Retro Rig Photo Thread
Reply 2560 of 3179, by eesz34
Tempus wrote on 2023-12-30, 00:06:
This is my system. It is named after Qbix's DOSBox emulator. […]
This system is a long time project that I've had lots of fun putting together. It is very close to complete, but I have a few very minor changes planned ahead. The pictures are from different times in the project, so they are not showing entirely the current configuration.
The computer is an Intel i486DX2 66Mhz on a ECS UM4980 V 1.1 motherboard, with 8 ISA expansion slots, whereas 3 are VESA local bus.
It has 8MB of RAM and 256KB of cache.
Drives:
- Seagate ST38410A HDD
- Compact Flash drive (8GB card)
- Quad speed CD-ROM
- PCMCIA card reader with 2 slots using 2 x 16MB flash cards.
- Floppy drive
- Gotek FlashFloppy with rotary encoder and OLED screen
Expansion cards:
- Roland Sound Canvas Card SCC-1A
- Roland LA PC Card LAPC-I with Roland MCB-1
- Sound Blaster Vibra 16 CT2800 (OPL3)
- Gravis Ultrasound PnP with 8MB of RAM
- SCM Swapbox card (interface for PCMCIA card reader)
- 2theMax ET4000/W32i VLB 1MB
- SST-2948 Super I/O Card VLB
- 3Com 3C5098-TPO NIC
Other:
- Gravis Gamepad Pro
- Gravis Analogue Pro
- Roland MT-32 rev0 (connected to the MCB-1)
- Roland MA-7 speakers
- Roland M-160 mixer
Is the case by any chance the huge tower that someone on eBay is selling?
Reply 2561 of 3179, by mmx23
Work in progress. Intel Aurora motherboard with 450KX chipset. Configuration will be Pentium PRO 200 256KB cache, 64MB Edo ram, scsi 16x cdrom, 9 GB Scsi hdd on aluminium rack, Matrox Millenium 4 MB + 3dfx Voodoo 2, soundblaster awe64, network card full atx case.
Reply 2562 of 3179, by amadeus777999
mmx23 wrote on 2024-01-07, 13:05:
That's one swell looking board!
Reply 2563 of 3179, by mmx23
Work completed.
Installed win98 and Nt4.0 sp6 . I'm very pleased with the results. The motherboard is made in week 42, year 95, all original.
Some w98 results from Everest: Hdd linear read transfer rate is 25 MB/s, random read is 20 MB/s, Ram move transfer is 100 MB/s, GLQuake 1 640x480 demo test returned 66,8 fps; quake 2 in 640x480 runs at 33 fps - demo001, Quake 3 at 512x384 demo01 returned 19 fps.
Hdd is a Seagate Barracuda 9GB 7200 rpm w 1 MB cache. Hdd is placed in a beautifull aliminium rack, with voltage and hdd temp monitoring, dual fan, it makes the system to look beautifull. More stickers with Pentium PRO and 3dfx will come, I have to print them on a clear adesive coat. For voodoo2 I've used FastVoodoo 4.0 drivers.
Reply 2564 of 3179, by pan069
mmx23 wrote on 2024-01-07, 19:49:
Work completed. Installed win98 and Nt4.0 sp6 . I'm very pleased with the results. The motherboard is made in week 42, year 95, […]
Work completed.
I had this case in the early 2000's. In my memory there was a front panel that could slide up/down to cover the drive bays... 🤔
Reply 2565 of 3179, by mmx23
Yes, normally has a sliding front panel. I found this case thrown away at dumpster 4 years ago,
it was in horrible condition, very dirty. But other than the missing door it was complete. It still has few scratches tho. Is very solid, don't know the case name or manufacturer, I found only a stamp with Made in Taiwan.
Reply 2566 of 3179, by snoopy23
Do you have more informations about that Aluminium bay with lcd? Looks really good
Reply 2567 of 3179, by mmx23
I've bought it from ebay few years ago, come in white or black color, support sca ultra 320 scsi drives and connect with 80 pin to the controller. It has monitoring for :
12v and 5v with selectable 5 or 10% tolerance ; Hdd temp monitoring via temp sensor cable;
hdd activity led and icon on the display;
Failure light indicator;
Dual fan with front fan working all the time and back one comes in whem the hdd temp threshold - which is selectable- is reached. When alarm comes in, there is a buzzer which beeps which can be turned off.
Also the scsi ID can be setup and is displayed on lcd.
From what I see there are only few black mobile racks left to a seller from UK, if you are interested search on ebay for 'Mobile rack, caddy for 80-pin SCA Ultra 320 SCSI hard drive. Black.LCD.Alum'.
From my point of view this is the most best looking and featured rack I've seen.
Reply 2568 of 3179, by snoopy23
Thanks! Maybe I’ll find the beige version one day
Reply 2569 of 3179, by DerBaum
snoopy23 wrote on 2024-01-09, 08:10:
the bezel doesnt have any markings on it... a thin layer of beige paint should do the trick (to keep the structure).
Then you could even choose exactly the type of beige your case has.
Just an idea... because of the less common nature of this "Intelligent Design Enhanced Mobile Rack SI-146"
http://www.corvintaurus.de/werkstatt2_hdd_wec … lrahmen_1-2.php
FCKGW-RHQQ2
Reply 2570 of 3179, by Hans Tork
Nothing special but I present my "retro" XP build based on my childhood 478 socket Intel Pentium 4 2.4 GHz processor. It took me quite a lot of time and effort to assemble this but with the help of the forum members I finally managed to piece together something close to what I wanted.
I changed the power supply in the first pic from logisys to a more reliable one as the previous psu was acting weird. I also had to replace the old Intel fan with a Startech one as the plastic retention mechanism did not fit the Dell board and it ended up breaking around the edges when I applied a bit of force to it.
The motherboard is a measly Dell dimension 3000 and I am yet to get a good GPU(I have put a pci fx 5200 as I am limited by the PCI only motherboard) but I would say this works for now. Coming to think of it I may even try to get a Win 98 installation on this rig.
Hopefully my future XP builds would be better as I am a XP fanatic.
The attachment IMG_0367.jpg is no longer available
The attachment IMG_0368.jpg is no longer available
The attachment IMG_0375.jpg is no longer available
The attachment IMG_0385.jpg is no longer available
i7/Titan X/X-Fi- XP
P4/X800/Audigy 2 ZS- W98
P3/Voodoo 3 3000/AWE 64 - W95
Reply 2571 of 3179, by snoopy23
Not sure yet where this is going, just started to put some drives in and see if it looks good. For the system itself I have different options in my mind.
Reply 2572 of 3179, by mtest001
Wow, first time I ever see the 5 disc CD charger, did not know this existed. I would have loved to have it back in the days!
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 2573 of 3179, by PD2JK
Yeah, play Atlantis or C&C with both add-ons with only a push of a button. How convenient. 😀
Edit; Huh... Both games feature Seth as a character (hello chinny22) 😉
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2575 of 3179, by DerBaum
dr_st wrote on 2024-01-14, 18:13:
PD2JK wrote on 2024-01-14, 17:31:
Indeed. 😀 How does it work physically?
This system seems to push the cd forward and move the laser/motor and the top clamp towards the slected cd.
FCKGW-RHQQ2
Reply 2576 of 3179, by FMV Master
DerBaum wrote on 2024-01-14, 18:32:
This system seems to push the cd forward and move the laser/motor and the top clamp towards the slected cd. https://i.pcmag.com/ […]
This looks impressive and I suppose a little bit on the expensive side right? At least in those years... Never saw one before and never knew they existed for PC.
Reply 2577 of 3179, by songoffall
Here's one of mine, my "Warhorse" build.
AMD Athlon XP 2000+, Asus A7NBX-VM/400, 512Mb Samsung 333MHz CL2.5 DDR SDRAM, Sparkle GeForce4 MX440, Creative SoundBlaster Audigy 2, Seagate Barracuda 7200RPM 40Gb
P2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 HT 3.0GHz/GeForce FX 5500/Creative Audigy 2
Core2 Quad Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 2578 of 3179, by Dwaco
songoffall wrote on 2024-01-17, 12:37:
Here's one of mine, my "Warhorse" build. […]
Noctuas are indeed the cherry on top of the old stuff... But, but, but ... you have space, why not give hard drives room to breathe?
PC: HP Kayak XU800 [2x PIII 1Ghz, 512 Mb RAM, Voodoo3 3000, SB Audigy Platinum EX]
Sparc: Blade 1000 [2x US-III, 3Gb RAM, 2x 73Gb FC-AL 10k, XVR-1000], Blade 100
PA-RISC: HP C3750 [FX10Pro]
Sony F1XDJ, A1200, C128
Reply 2579 of 3179, by songoffall
Dwaco wrote on 2024-01-17, 19:05:
They aren't getting particularly hot, and there's another fan down there I need for the intake.
One thing that does get hot is the south bridge, need to add a heatsink with adhesive thermal tape, I think.
