Reply 440 of 1618, by sharangad
demonized999 wrote on 2024-01-10, 12:24:
Do you still need something to be run on V1000?
I have miroCrystal VRX here.
This
Could you try this as well? (On a single card)
https://1drv.ms/u/s!As-dKk-N73dSlw8Mo-Zu9Ad0nTvO
MD5: 4cd999b10c26e7293cecfa7c2280da8f
I need the redirected console output and the other txt file it creates. I'll also need a dump of your video bios (segment c000:0000). It has to be the bios the test app ran against.
[EDIT] I haven't got any results from a V1000 yet.
https://www.youtube.com/@sharangadayananda
Reply 441 of 1618, by demonized999
Sorry - I had some other stuff to finish yesterday 😀
Here are the results attached alongside the video BIOS of the card
Reply 443 of 1618, by sharangad
The V1000 is the same as the V2100 and V2200.
The specific address is different because it has a different bios location for the id string.
Reply 445 of 1618, by sharangad
Yes it is. That pretty much guarantees the address returned always points to a some sort of identifier and some other data in the BIOS terminated by a 'y' character.
Now it's a matter of seeing what this data is used for. So far all I know is it counts how many characters there are until it hits the 'y'.
vQuake uses paging to access the BIOS using a different address, that threw me off for a while. But even there it searching a a 'y' character and counting.
In all the Verite BIOSs I've looked at at the returned address there're a couple of bytes followed by "Rendition Reference Board" more bytes, some of which could be strings. The boards I've looked at a Steal II, nameless V2200, and your MIRO V1000 all return a pointer to that block in the BIOS as an offset in register CX and a segment in DX.
It's what gets done with afterwards that doesn't make any sense either that or my assembler is really really terrible (probably is).
Reply 447 of 1618, by sharangad
Win95 build? Is that rredline?
If it is I was unaware of that.
Will test and see. If it isn't rredline speedy3d support is needed and that's nowhere near ready yet.
My large text file viewer is almost done. Should be able to jump right back into working on dos support.
Reply 448 of 1618, by Deffnator
sharangad wrote on 2024-01-30, 01:10:
Win95 build? Is that rredline? […]
race sim central guys have more info on it
https://racesimcentral.net/indycar-racing-ii- … ion-experience/
Reply 449 of 1618, by sharangad
Deffnator wrote on 2024-01-30, 12:54:
I *think* that's the DOS version that has Rendition support. If there's a Windows version with Rendition (RRedline on Windows) then the game would already be running.
Reply 450 of 1618, by BEEN_Nath_58
sharangad wrote on 2024-01-30, 13:01:
There's no RRedline IndyCar Racing 2
Reply 452 of 1618, by sharangad
Back on the job:
I just realised SetMode left out a critical bit of info. The stack pointer. This is critical because I don't know whether any extra parameters were passed on the stack:
https://1drv.ms/u/s!As-dKk-N73dSlzcMo-Zu9Ad0nTvO
MD5: 5371fed7181333a8abe948069c7d91a3
V1000/V2000. What I really need is the console output from the app.
Thanks guys.
Reply 453 of 1618, by Agent of the BSoD
Haven't watched this thread in a little bit. Here's results from the last post. Let me know if you need me to run any of the earlier ones.
V1000
    SETMODE.TXT
    187 Bytes
    18 downloads
    000009FC.TXT
    2.84 KiB
    17 downloads
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 455 of 1618, by RaVeN-05
V2200
Say please if v2100 needed also?
    SETMODE.TXT
    187 Bytes
    14 downloads
    000009FC.TXT
    2.85 KiB
    15 downloads
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 456 of 1618, by sharangad
RaVeN-05 wrote on 2024-02-09, 13:23:
V2200
No. This should be enough. Thanks Raven.
Reply 457 of 1618, by sharangad
Once more with feeling:
https://1drv.ms/u/s!As-dKk-N73dSlzsMo-Zu9Ad0nTvO
MD5: eb772a4a880b99942b3c58b04fc67cff
[EDIT]. SetMode again.
Reply 458 of 1618, by RaVeN-05
on v2200
    SETMODE.TXT
    293 Bytes
    14 downloads
    v2200
    000009FC.TXT
    2.85 KiB
    15 downloads
    v2200
